Move
Move 3.2.2
Hi, I have a problem with the transition. Note that I make a very simple use of it, basically I only use it for the transition between scene and scene and in previous versions this thing did not happen. The problem shows both with Decklink Out and in the recording. The problem concerns the audio in case there are two elements, one that disappears and another that appears in two different scenes. If I apply the fade transition basically it doesn't work, that is, the audio goes to zero in the disappearing and at 100 in the next as if it were in cut. If instead I don't select any transition, the audio goes to fade out and fade in correctly (in theory it shouldn't go to fade), but obviously not the video. Has anyone identified this behavior? I use the latest version of MOVE (3.2.0) and the latest version of OBS MACOS Silicon (32.0.3). Thank you.
@Exeldro If I'm not mistaken the `NVIDIA AR Move` filter (that I'm using as a face tracker) is causing OBS to freeze. I'm using said filter on a camera source with the following settings:
OBS doesn't crash (so no crash logs available), but I see several of the following entries in the regular logs (see attached sample) leading up to the freeze:
`[Move Transition] Error in Map Resource; error -1099: unknown error`
`[Move Transition] Error in Unmap Resource; error -311: resource not mapped`
Hi all,
Recently when updating my plugins, the .pkg file failed to install the move plugin. I've tried a number of attempts, system restarts, and even had others share the unzipped .plugin file to put in the appropriate directory. I've had no luck, and really am in need of getting the plugin working again. Despite all my attempts, this is what the plugin manager is showing me:
I've checked the two areas I suspect OBS may be looking for the plugin to be, but neither of those directories have the move .plugin file, so I'm really not sure what other options to consider.
I am running an M4 MBPro, OBS 32.02.
Has anyone ever encountered this? Better still - has anyone resolved something like this?
i installed Move 3.2.0 on Mac M1 with newest OBS. And i saw plugin in Tools > Plugin Manager
But in screne transitions i did see anything. How to enable Move plugin ???
Hello @Exeldro, thanks for the wonderful plugin - would love to get started... but I'm coming across this issue when looking to install the plugin
Your thoughts on working around this?
Here are the things I've tried already:
-reinstall OBS
-Reinstall MacOS from Tahoe down to Sequoia 15.7.3
-Deleted the entire Hardisk setup and reinstalled MacOS.
-lowered the gatekeep installer mechanism (currently at the lowest installation)
Using Mac Studio 2025 M4 Chip 64gb memory
Thanks for all that you do! plus looking into this problem with me.
-Y
-reinstall OBS
-Y
I solved the problem - the issue is with the 'authorized user'
Solution:
in the installer app, when the error shows up, I downloaded the log error and I asked chatgpt to ask me what is wrong -
the answer was that the ‘author’ was set to “root” rather than myself as the user and hence it was a permission issue.
I asked chatgpt to prompt me correct terminal instructions, and then after that - I was able to install it.
does anyone have any issues with the cache setting only working when it wants to?
i have a couple move source filters on my scenes and i have a couple move value filters on my camera. they are controlling an advanced mask, crop/pad, and a drop shadow filter. doing all three at once when i change scenes for some reason brings my pc to it's knees when i'm recording and streaming. some of the most basic moves.
i also have the transition table plugin to add some transition overrides. so for example instead of a move, i set a cross dissolve from my camera full scene to my brb scene.
i have caching enabled, but when i go to my brb scene to my camera scene then to my game scene, it seems to reset or something. i get heavy encode lag when i do the moves. sometimes i get encode lag when i do a cross dissolve. something as basic as that causes encode lag.
doing the moves a couple times fixes the lag, but when i do the cross dissolve, the lag comes back. i don't know if this is a bug with the plugin or obs or if this is something on my computer or what, but i just wanted to share what i'm experiencing. if anyone has any suggestions, please let me know!
Hi @Exeldro
The `move action` and `move value` filters are having problems with vertical scenes.
The `move action` filter doesn't relate vertical scenes in the filter enable option. The `move value` filter doesn't work when I try to adjust the properties of the `move source` filter applied to vertical scenes.
I tested the features on Windows 11 Pro and Linux Mint 22.2 XFCE, obtaining the same results.
Thank you in advance.
I have a problem after upgrading from version 2.9.1 to a more recent one. 3.2.0. If there are no sources on another scene, then on the first one they simply disappear into the distance during the transition (visible on the video). How can I fix this? Previously, on 2.9.1, any scene was static during the transition and did not disappear anywhere... Someone help with this issue!
Hey @Exeldro
First of all, I want to thank you for your work on this amazing plugin.
I'm using Move combined with Advanced Masks: I got Move Action filters on my scenes wich are enabling different Move Value filters on an unique source (depending on the active scene). For exemple, these Move Value filters change the width of the Advanced Masks.
I set the Start Trigger of my Move Action filters to Activate, wich works perfectly when I change the active scene. But my problem is that I'm using the Studio Mode during my streams, and there is no Start Trigger on the filter that works with this display mode.
Did I miss something? I hope I have been clear enough about my usage to be understandable.
In any case, thank you in advance.
And have a great day, everyone! ✨
Huhu @Exeldro
I love your plug in and used it on my old set up! Now I will start streaming again and off course with your move transition plug in! ^^
But I’m having an issue with Move Transition not showing up in OBS.
The plugin loads correctly (confirmed in the log: “[Move Transition] loaded version 3.2.0”), and Move / Move Value filters are available, but Move Transition does not appear in the Scene Transitions (+) list.
I’ve already:
- tried OBS 31 and 32 (Windows 64-bit)
- reinstalled OBS and the plugin
- installed manually with the correct folder structure
- reset the UI / transitions
- checked the log (plugin is clearly loaded)
Any help would be appreciated, thank you soooo much! <3
Hello, I'm having the following problem. I'm using the Move plugin to move a scene, and that works fine. I'm using a Mac, but I want to control and move my Insta360 or OBS Bot webcam using "Move Video Capture Device." However, this filter isn't showing up. What could be the reason? Is it possible that Macs don't support this?
Hey First of all i love this Plugin. I have the issue that when i try to move a source and want to set the position with the get transform button nothing happens. am i missing something?
nevermind if found the problem. i was applying the filter to the source and not to the scene
Hi to everyone,
I still have the audio/general problem (macOS Tahoe, latest OBS), when I use the move transition at the scene level (OBS scene transitions). When I activate a transition type (cut or fade), in the transition settings for appearing or disappearing items, the behavior is reversed between audio and video.
If I set cut, the video appears correctly in cut but the audio fades, if I activate fade, the video appears correctly in fade but the audio cuts. Has anyone else noticed this problem? Thank you.
