Move
Move 3.2.2
Heyo, wondering where the scene transistions are stored? I was able to copy my profile and scene collection but im missing my custom transistions (this may be due to the fact i didnt install move transistion on the new system first?)
Hello, I recently discovered this and I am trying to match Audio move to my audio which is in negative DB.
However, Audio move threshold is set at 0 as the based minimum.
Can someone help me how do i fix this?
Hello
In the Audio move filter. Under the Scene category, this is only like OBS scenes right?
Using another plugin that creates vertical scenes and can't find those. Will this perhaps be implemented in the future?
Can you PLEASE remove that when we update a source name or change from one source to another, the transform values reset? 99.999999999999999999% of the time i need the transform values to remain the same, not get updated to the current transform values of the new selected source, would save a TON of time. Thanks and please
@Guuvita that can only work when the source has the same bounding box type and alignment. To keep it consistent with all sources I prefer to keep it the way it is.
@Exeldro, this remarable, outstanding plugin works with streamelements multistreaming plugin? I ask because when the transition on the main canvas is smooth, then on the others created in multistreaming, they switch abruptly, without transitions, jerkily.
@KhaytovHit I have not tested it with the streamelements plugin. As long as they don't do anything strange it can work. Does streamelements let you select which transition it uses?
I tested with the Aitum plugins for multistreaming and they work as expected for me.
thank you a lot for fixing the leak, bruv!
Please, consider fixing the lack of ability to add delay for Actions, like Source Visibility. Before I could add a delay before or after Enabling a source, not I can't see an option to add delay, even so I could before, and even old delay saved, it's just doesn't show in the filter settings.
It works in Move Value, but not in Move Action.
Yes, it is. In settings for all canvases present option: "Scene Transition -> Use same transition settings as OBS"
I have your wonderful plugin installed in my OBS, and when I change the transition duration, it almost always crashes with an error, and I have to restart OBS twice: in safe mode and then in normal mode. Most likely, the problem is with StreamElements Multistreaming. Because when I install OBS from scratch, after connecting my StreamElements account, OBS starts crashing. However, when I change any of the Move plugin settings, my OBS crushed in 80%. Perhaps the problem is also my faulty hands.
Problem was in streamelements multistream plugin!
I tested OBS portable with portable_mode.txt and with aitum and with all installed mods, included Move, and obs works like a charm: stable, fast WITHOUT ANY crush! This little bastard multistream plugin from streamelements. :(
Hello!
Having an issue with Move AR on a cloned source that is flipped horizontally from the original asset.
The asset tracking a face landmark moves opposite horizontally as if it’s still tracking the original (unflipped) source. I move left, the asset moves right.
I have tried applying the filter and asset I want moved a few different ways with the same result. Anyone able to overcome a similar situation?
Hello !
I'm just discovering this plug-in and I tried to make some things work but I don't seem able to.
Let's say I have a blue square .JPG file on my Scene A.
I want it to become red little by little when I show Scene A to my viewers.
That part, is ok.
Now for the part I can't figure out how :
- I want the transition to only start when I switch to Scene A.
- The moment I switch to Scene B, I want the square to go back to its initial color. That way, when I start Scene A again, the animation happens just like before.
- I also want the square to stay red until I switch to Scene B.
To put it in other way : I want it to act just like a video source that restart everytime I display my Scene.
My goal is to make slow transitions of differents elements without having to put heavy 10 minutes videos on my scenes.
I'm sure it's possible and easy to do, but for some reason, I don't find the right way to do so. I think I don't really understand what the Start and Stop trigger are.
If anyone could help, thanks a lot !
Okay, sorry for the self-reply, but after a few hours, I figured out what was wrong : the add-on doesn't like long custom durations.
I wanted to make a duration 300000ms long (5 minutes) because I wanted my stream's waiting screen to shift slowly with differents moving parts.
I made a Move Value of 300000ms that should trigger when launching my Scene.
I made another Move Value to reset to previous settings when I'm exiting my Scene.
It works once or twice when I put a small duration and then put back the 300000ms duration, but it doesn't work anymore when I start OBS again (which means I have to input back the duration in all my Move Value filters everytime I restart OBS).
Is there a way to bypass this problem?
Maybe we could have a checkbox that disables auto updating the transform field? that way you can keep your preferred behavior by default but give us more options? I would prefer updating 1 bounding box and alignment than having to change 20 filters with the same positions that would need to remember or manually reposition in the scene... less than 1 minute vs over 30 minutes... If you still don't want to is ok, it's your plugin, it's free, can't complain... won't insist again. I'm just unable to understand why make updating sources this annoying and time consuming :(
Hi, I currently have a problem with Audio Move.
On Linux Mint, trying to create an audio move filter just doesn't work for me; OBS just crashes and doesn't leave a log (I checked the log folder, didn't find anything useful). It does work on Windows 11 which is kinda odd. A log file is currently attached here.
Currently using a dual-boot system, Linux Mint 22.2 Cinnamon and Windows 11
Also would like to ask if anyone else has the same problem (and if theres a solution, if possible)
Edit: All other filters relating to Move doesn't work. Could be user-error.
All things aside; great plugin.
Hello, @Exeldro Could you pls explane what should execute move action at PROGRAM? When i'm testing the plugin is only active in PREVIEW. The toggling activate the scene at PROGRAM and PREVIEW is not parallely showing this action.
forgot to mention: this problem is when filter is in SCENE. in GROUP it is working properly.
