Move
Move 3.2.2
Hello, does this work with Aitum Vertical? I have the horizontal canvas working perfectly, but the same settings in the vertical transition don't seem to work beyond the default settings. After changing the properties of the vertical transition, the animation is exactly the same. Sorry if this has been asked before.
Solved: I realized I was getting a lot of issues in my vertical transitions due to "with the last word removed matches the other source name" being checked. If you're seeing unexpected transition results in Autumn Vertical, try turning that off.
If you need to, you can try the Move Transition Override filter on the scene in order to manually match 2 sources.
Hi there ! first off, a huge thank you for what you do! @Exeldro
I see there are some other issues with the Aitum Vertical plugin, but right now, it’s the only one that really gets it right... the vertical smartphone format is clearly driving this trend, so platforms are following suit, and streamers are too.
I experienced crashes due to an audio memory address issue.
Edit: I should point out that the crash occurs after several hours of streaming on average, 5 or even 7 hours in.
I used Gemini to help me out:
Title: Crash (0xC0000005) in move_enum_active_sources when running alongside Aitum Vertical Canvas
Description
An access violation crash (0xC0000005) occurs on the audio-io thread during concurrent source enumeration. This issue appears when using Move Transition together with Aitum Vertical Canvas, especially in setups featuring nested scenes or shared audio sources.
Crash Context
  • Thread: audio-io
  • Exception Code: 0xC0000005 (Access Violation)
  • Faulting Modules: move-transition.dll / vertical-canvas.dll
  • Relevant Call Stack:
    • move-transition.dll!move_enum_active_sources
    • vertical-canvas.dll!audio_wrapper_enum_all_sources
Suspected Root Cause
A race condition occurs when move_enum_active_sources traverses the active source tree while Aitum's audio wrapper simultaneously enumerates/modifies sources across canvases. Move attempts to read a source pointer that has become invalid or unmapped during the iteration without proper mutex locking or ref-counting.
Suggested Fix
  • Add explicit null-checks and status guards before inspecting sources (e.g., `if (!source || obs_source_removed(source)) continue;`).
  • Protect source lifecycles during iteration using `libobs` reference counting: call `obs_source_addref()` (or `obs_source_get_ref()`) before dereferencing, and `obs_source_release()` once processing is done.
  • Guard the tree traversal in `move_enum_active_sources` with scene/source mutex locks or safer enumeration callbacks to prevent data races with third-party audio wrappers like Aitum on the `audio-io` thread.
@KnB I made a fix, you can download the test build when logged in on GitHub from the bottom of this page:
The very day you posted the fix, I started using it I wanted to make sure I ran several tests over a period of time. And now, after a number of long streaming sessions... there haven't been any conflict issues whatsoever! Great work!
Exeldro updated Move with a new update entry:
Version 3.2.2
  • Add setting group support to move action filter
  • Add new OBS 33 folder structure
  • Fix render of move filters
  • Fix compiling for OBS 33
  • Fix audio move update setting only on change
  • Fix start delay breaking fade transitions
  • Fix crash enum tree from not graphics thread
  • Fix edge position for rotated sources
  • Fix HDR being converted to SDR when Move transition is active
Hi there! Sorry if it's not the proper place to be asking, but I've been going insane trying to fix it lol
I've updated the plugin and OBS, and recently I've been trying to sort my things in OBS and put them in folders, but for some reason the move plugin just doesn't work when I put the move filter on the folder itself. It works fine if I put the filter on the scene, but then that moves the whole folder, which sometimes I need things to move individually. I know I could just make a nested scene, but I'd much prefer to use folders if possible since I'm trying to keep my scenes to a minimum. I could also just not use folders but I'm trying to keep things organized and all
Is this like a known issue or is my plugin broken somehow? I appreciate any help!
Nevermind he replied to me on discord, thanks for the help!
Log spam: "Attempted to add Scene without specifying a canvas!" when using Move Transition with Aitum Vertical
Whenever I use the Move Transition plugin on scene items (for example, as a Hide Transition) alongside the Aitum Vertical plugin, OBS repeatedly logs the following warning:
Attempted to add Scene without specifying a canvas! Using default canvas instead.
The transition itself works as expected visually, so functionality isn't broken. However, it continuously spams the OBS log file, and there is currently no setting on my end to specify a canvas and prevent this warning.
Environment
  • OBS Studio Version: [e.g. 31.x.x, Portable Mode]
  • Move Transition Version: 3.2.2
  • Aitum Vertical Version: [e.g. 1.x.x]
  • OS: [e.g. Windows 11]
Steps to Reproduce
  1. Have both Move Transition and Aitum Vertical installed.
  2. Assign a Move Transition to a scene item (e.g., as a Hide Transition with Match Nested Scenes enabled).
  3. Toggle the visibility of the scene item (specifically disabling it to trigger the Hide Transition).
  4. Check the OBS log.
Expected Behavior
Move Transition automatically uses the appropriate canvas context without generating warnings in the OBS log.
Actual Behavior
Every time the transition is triggered (in the log below, immediately after disabling the scene item), OBS logs Attempted to add Scene without specifying a canvas! Using default canvas instead.
Log Excerpt (source and scene names anonymized)
02:10:39.815: Last log entry repeated for 23 more lines
02:10:39.815: Attempted to add Scene without specifying a canvas! Using default canvas instead.
02:11:17.140: User set sceneitem 'Example_Item' (15) on scene 'Example_Scene' to disabled
02:11:17.142: Attempted to add Scene without specifying a canvas! Using default canvas instead.
02:11:19.277: User set sceneitem 'Example_Item' (15) on scene 'Example_Scene' to enabled
02:11:21.404: User set sceneitem 'Example_Item' (15) on scene 'Example_Scene' to disabled
02:11:21.409: Attempted to add Scene without specifying a canvas! Using default canvas instead.
02:11:27.032: User set sceneitem 'Example_Item' (15) on scene 'Example_Scene' to enabled
02:11:29.179: User set sceneitem 'Example_Item' (15) on scene 'Example_Scene' to disabled
02:11:29.192: Attempted to add Scene without specifying a canvas! Using default canvas instead.
02:11:35.077: User set sceneitem 'Example_Item' (15) on scene 'Example_Scene' to enabled
Is there any workaround to avoid this warning, or could this be addressed in a future update? Thanks!
@Garlandt that looks like an issue from an old OBS version can you try on OBS 33 ?
I use OBS Version 33.0.1 and the error is repeatable.
I entered a Scene, created a color source. Added a hide and show transition to it using "Move".
06:14:11.965: User switched to scene '[S]  Talking Head'
06:14:19.958: User added source 'Farbe' (color_source_v3) to scene '[S]  Talking Head'
06:14:56.380: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:15:31.253: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:15:49.711: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:15:49.711: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to disabled
06:15:50.877: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to enabled
06:15:50.878: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:15:57.961: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:15:57.961: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to disabled
06:15:58.691: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to enabled
06:15:58.694: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:02.134: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to disabled
06:16:02.135: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:03.071: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to enabled
06:16:03.077: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:05.310: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to disabled
06:16:05.311: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:05.984: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:05.984: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to enabled
06:16:06.884: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to disabled
06:16:06.894: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:07.467: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to enabled
06:16:07.468: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:12.429: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to disabled
06:16:12.434: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:13.677: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to enabled
06:16:13.678: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:15.386: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to disabled
06:16:15.394: Attempted to add Scene without specifying a canvas! Using default canvas instead.
06:16:16.002: User set sceneitem 'Farbe' (44) on scene '[S]  Talking Head' to enabled
06:16:16.011: Attempted to add Scene without specifying a canvas! Using default canvas instead.
Hi Exeldro,
after updating Move to version 3.2.2, the plugin no longer loads. The OBS log shows that Windows is blocking the DLL:
LoadLibrary failed for '../../plugins/move-transition/move-transition.dll': An Application Control policy has blocked this file.
 (4551)
Module '../../plugins/move-transition/move-transition.dll' not loaded
Smart App Control is enabled on my system. I already tried unblocking the DLL via file properties, but it is still blocked. Since Smart App Control does not allow exceptions for individual files, the only workaround would be to disable it completely. I would rather not turn off a system-wide Windows security feature just to get one OBS plugin working.
The previous version of Move worked fine with Smart App Control enabled.
My setup:
OBS Studio 33.0.1 (portable mode)
Move 3.2.2
Windows 11 26H2 (Build 26300)
Is the DLL in 3.2.2 signed? Would it be possible to provide a signed build?
Full log: https://obsproject.com/logs/bOpU57vHSrgwVReN
Thanks for your great work on this plugin!
@d3bu663r 3.2.2 is not signed. At the moment I don't have a signing certificate as the signing authority I used won't validate me anymore without making private information about me public.
Thanks for the quick reply and for explaining the situation, I really appreciate it.
Do you think there will be a solution in the near future, for example a new certificate from another signing authority? I'm asking because my whole OBS setup relies heavily on Move, especially the Move Source filters in my scenes. If there's no way to get a signed version, I would either have to disable Smart App Control or rebuild large parts of my setup without Move, and I'd like to avoid both if possible.
Thanks again for all your work on this plugin!
@Garlandt I was able to replicate the warning message. There is no way for the plugin to remove that warning message from OBS at the moment. The message can be ignored. Best is not to use move as show or hide transition.
@d3bu663r for now I would use an older version of move that is signed.
Yes, that's what I'm doing at the moment. I just wanted to make sure there will be a solution in the future, because plugins in the old locations are only supported until OBS 34, so the older version will probably stop working at some point. :(
Thanks again for your help!
Thank you for the quick reply and your awesome work on all the plugins in general.
I suppose I could take the opportunity to suggest a feature while I'm at it. I'd like to have the Hide and Show Transition move the objects from outside the canvas into their positions on the canvas. Currently, they appear "out of nowhere" and move into position, which is fine, of course. At the moment, I use a workaround with scene filters like "Move Object In" when it's shown and "Move Object Out" when it's hidden.
