Move
Move 3.2.2
Is there a way for the "move scene" filter from one Scene, trigger the "move scene" filter configured in another Scene?
I setup to move my FaceCam in a nest scene ("Face Cam Overlay") to a different corner, in case the game I'm playing has important stats/info in the current corner.. But I have music player in another corner, follower stats in another.. I'd like to trigger, for example, the music player (which is in nested Scene called "Music") to be hidden based on the "FaceCam" sliding over to that corner.
Also, clicking the "Get Transform" button, it doesn't detect if the "source" has been flipped horizontally or vertically.
Is there a way to flip the source as its moving?
So I managed to figure out the whole moving a source issue..
but now for some reason the Move Transition doesn't work at all for any Scene that has a Nested Scene in it.. It works perfectly fine clicking between the unNested Scenes themselves.
We've used your MoveTransition Filters for a long time to simplify the management of scenes and sources within OBS, so that our volunteers don't get lost-in (or forget) important details during our broadcasts. - And your plugins work great. We use your widgets extensively to fade-in/fade-out subtitles, show or hide visual overlays, turn on (or off) the Virtual camera, start/stop recording, etc.
That said, we'd like to do something similar with the audio feed: We do all of the audio mixing externally, then feed it into our windows machine via USB, which we feed into OBS as an audio Input. I'm trying to use your Audio Move filter to (1) enable the OBS Audio Mixer source we're using, then (2) set the audio level to a reasonable value. Can't figure out how to do that. Any guidance or help would be appreciated.
I am using a MacBook Pro M2 Sequoia 15.2 with OBS versions 30.2.3, 31.0.0, and 31.0.1. I use the Move plugin for automatic audio adjustments. However, after adding the plugin, OBS crashes either immediately or after some time, especially when switching scenes. I kindly ask the developer to update the plugin to support macOS M2. Thank you very much for creating such a great plugin!
Note: I have installed the v.arm64 version of the program.
@natakitsmart can you provide a crash report?
Open Console.app (Located in /Applications/Utilities).
Navigate to the Crash Reports view along the left sidebar, then sort the table by date to find the most recent crash with the OBS process name.
Can you help me figure out what's causing this issue? I never experienced this problem when using Windows, but after switching to macOS, plugins often seem to cause trouble. Thank you in advance for your assistance!
@natakitsmart that crash is when editing a move value filter on a mac capture source. The crash is in getting the properties of a mac capture source. I don't know enough of mac capture to know what might be causing a crash in that.
Hi!
I've been using the Audio Move filter for my png-tuber for a year on previous OBS versions and it worked fine, but on 31.0.1 it stopped working.
I'm on Mac Sequoia 15.2
The attached images are the filters on my mic.
When the Threshold is set to 0 the "talking" image shows up, but even at 0.01 it doesn't do anything.
Any ideas would be greatly appreciated, thank you!
Having issues with the plugins move video capture device. I have a Insta360 Link 2 and when I set it up the movement is very stuttery and not smooth, sometimes it doesn't even move completely to the area I set. I watch nutty video with the first one and it seemed so smooth. Hope this is something that can be fixed cause it was the reason I spent money on the link 2.
P. S. I'm on newest update of the move plugin.
Hi there tried following the andilippi video for moving sources within the same scene with "move source" but it just says the "filer only works on scenes and groups" so how to move transition a SINGLE SOURCE?
I used this plugin for resizing my cameras in real-time, and it works... (but only in my Preview screen). I must be missing something obvious, because Preview looks great, Program only shows my pre-triggered state (until I transition Preview to Program). Any help would be great.
Hey
I think I found a problem while updating my OBS.
I used version 3.0.2 before and am now on version 3.1.1.
The new version has now way of using NO Zoom with appearing or disappearing items. I recorded a video showing the diffrence here:
Direct Link to video
As you can see. Even with 0% Zoom the items still shrink towards the middle and the checkbox for Zoom is gone entirely.
All other configurations are the same.
Am I missing something. I just wan't appearing and disappearing items to fade away, not move out of the screen or towards the middle.
I am having a hard time, installing this on mac os. I install the plugin and I do not see move as a option. I am on OBS 31.0.1. Is there something more I have to after installing.
@rahmi if you want move as a transition you should have it under the + button in the scene transitions dock. If that is not showing you can check the OBS log file to see if the plugin tries to load correctly.
I'm possibly missing something straightforward so please forgive me but is there a way to have a filter trigger on a specific scene?
I have an audio source that music comes through and I want to have different volumes on different scenes so for example it's quieter on a 'just chatting' scene in comparison to a 'starting soon' or 'break' scene. I've set up 'move value' filters that have different volumes that I can manually trigger but I was wondering if there is a way to automate it.
Thanks so much for all your awesome plugins!
The great Exeldro!
Might I suggest a feature for your move source or perhaps I'm not setting it up correctly? A sort of override for when you manually change scenes. I set it up and it works great the way I set it up, but when I manually change scenes quickly to compare, the setup stays there and not move at all, because I set the duration for a long time. I made 4 sources to fly in at different times and to stay there for a long time as each one flew in. When I would quickly go through many scenes it appeared not to work. I've deleted and started over many times thinking I didn't do it right. You've thought of everything with many options, so is their a setting that you could tell me about to do this or could you include this in the next update? It will probably save time for future OBS move filterers. Thanks for all do!
