Move
Move 3.2.2
move-transition-2.8.3-windows-installer.zip​
I remember I used to get just a general Microsoft Defender warning when I would try to run the installers that I could select run anyway, but with this the download actually won't finish.
Hey @Exeldro,
Big fan. Just wanted to report a slight bug with audio move, if the target source is grouped it will not activate, but once I move the source out of the group and back in it works again.
cheers and thanks for all your hard work.
Is anyone getting a Windows message about
Trojan:Script/Wacatac.H!ml​
from the latest update?
Same here, not me (still using 2.8.1) but a friend that I was installing OBS from fresh and the plugin last sunday.
Maybe it's a false positive, but not gona risk it. I instaled v 2.8.2 and no problem with that.
Hello Exeldro
Great plugin!
Does this new version of the plugin,work well with O.B.S 29.0.2? I was really pleased with how it worked with my video recordings,in the previous version of O.B.S
Would really like to use this excellent plugin again
Hey Exeldro! The 'Audio Move' filter can't select a Source that's been added to a 'Group'. The list of sources remains blank if a group has been selected in the 'Scene' dropdown.
This works momentarily if you select a source in the filter, before adding it to a Group.
Hi Exeldro
When choosing somethiing in combobox, it stretch the content of window, so i can't open combobox again. Resize window fix it.
Jesper
Hi Exeldro,
The move-transition effect between Matched Items works perfectly between two diffferent Scenes.
However, I've tried it between Sources that match inside a Scene, but it considered them as they weren't matched items.
As I use the script Source Toggler ( inside a Scene, when displaying a Source by clicking on the eye icon, it automatically hides all the other Sources), I was expecting to do the move-transition effect between Match Items for the sources that match.
Thanks in advance for your answer !
Odd thing, when a source is in a group you cannot use the "Move Action"" Action > Source Visibility option.
I tried typing in the sources name. Still does not trigger.
I am running OBS 29.0.2, Move Transition 2.8.3
The new AR update has been so much fun to play around with! Definitely nice to have a feature like this integrated into OBS now!
Just a small issue that I've already mentioned to Exeldro that might just be on my end. I initially had this working in tandem with the Auto-Framing feature in StreamFX, but now it suddenly does not work at all, even in a portable OBS install, and even after I tried uninstalling the move transition completely.
Not a huge deal in the long run since the Face Tracker plugin does the job nicely, though I do like the tracking quality of the StreamFX implementation ever so slightly. If anyone using StreamFX is able to confirm this or whether it's working for you, let me know!
Looks promising. Installed easily, but need to learn it on a Mac. However, do you need an Nvidia card or setup to use, the "NVIDIA AR Move filter?" Thanks.
Wow.. I LOVE the new AR feature. As always, great work @Exeldro ! I was wondering if it would be possible to add an option to set the position of the source when the face isn't visible (Default position).
