Downstream Keyer
Downstream Keyer 0.4.5
I've just reinstalled OBS in a new pc, along with the roaming/basic folder that contains all scenes and profiles. But the DSK panel is empty, all settings are gone. Any clue on how to find them among the old pc hdd files?
Hello exeldro, I have a problem with the latest update of this plugin, when switching between scenes in OBS they do not make the change, since it is not seen in the preview and not in the broadcast, remove the plugin and OBS works. correctly, I install it again and this problem appears again.
As you can see in the OBSBIEN image, I have the plugin uninstalled and the scene is recognized, and in the OBSMAL image it is when I have the plugin installed and it does not change scenes.
windows 11
obs 30.2.3 64bit
downstream keyer 0.3.2
aitum 1.4.8
i can't make aitum vertical canvas & downstream keyer works together
should i add the scene to downstream keyer dock?
it can only add scene from horizontal scenes
windows 11
obs 30.2.3 64bit
aitum 1.4.8
I have the same question.
Hi, I was wondering, I recently burned down my OBS and started rebuilding everything from scratch, I also went to the flatpak (Garuda Linux (Arch btw :D ) but with the latest version of OBS at 30.2.3 but I couldn't get DSK to show, but if I go back a few commits to version 30.1.2, the plugin is able to load. are there any plans to update for that or is there something additional that I need/ a work around that would work? I really love this plugin btw
Need help! I'm using OBS 27.2.4 (64 bit), after installing all version Downstream Key plugins, the menu "Downstream Key" is not shown in the docks, how should i do?View attachment 101993
Hi Bik, the solution is to change the version. I´m using OBS 27 and v2.3 Downstream-keyer and work it!
There are another version to download, but if you want to work with the same varsion... here you are the link:
Hi, I am using the MacOS High Sierra and managed to install OBS version 27. I have downloaded this Downstream Keyer and have performed the installation. The installation seems successful. However, the Dock does not show the Downstream Keyer plugin. Any hint of what went wrong?
Hi apa56khabar,
the solution is to change the version. Please read this post.
I suspect DSK is crashing on close. I ran this rig every week for many months before, and it was fine. Then I converted a bunch of duplicated scenes with different overlays, to fewer scenes with DSK. It still runs just fine, but now it asks for Safe Mode on startup. Using DSK 0.3.2 for Ubuntu 22.04, on Ubuntu Studio 22.04 and OBS 30.2.3.
Close OBS, reopen, decline Safe Mode, upload previous log:
The Analyzer doesn't say anything beyond the obvious (list of plugins, no output session because it's not needed to demonstrate the problem), and I can't tell much either...except that all the other plugins have closing messages at the end and DSK doesn't. Don't know if that means anything, but maybe it does???
reeeeally hated you guys today, prepared my broadcast one week ago counting on this plugin, suddenly stopped working with my obs, can't switch scenes with this f**** plugin, if I delete the files from the plugins folder everything works perfect. I wanna cry.
@nyoussefian sorry to hear that. It sounds to me you made a full size dsk that was hiding the scene changes under it.
I agree with Exeldro. DSK puts an entire scene on top of what would otherwise be OBS's final output. If that scene has content everywhere and no transparency, then you won't see anything behind it. Technically, you are still switching scenes, but the DSK'ed scene with no transparency hides it all.
So don't completely fill the scene that you're going to DSK on top of everything!
Okay I might be really stupid, but I can't find a way to turn the DSK dock vertical.
I've searched everywhere under the sun with NO luck at all, I'm on the most recent version unless I misunderstood how that works, would really appreciate just a bit of guidance. Thank you for the Plugin, it's been life saving even if it's a little complicated to figure out
Also - I just noticed I'm having a weird issue, with one scene it was my microphone, every time I started my OBS I had to turn off the source in DSK and then turn it back on, as soon as I went to migrate stuff over for another scene, I just reopened it and I was in the same boat, it was technically active but wouldn't show up until I paused and reactivated it.
Thank you VERY much for such amazing plugins, I don't know where my streams would be without your work <3
@NickTheGreekGeek For Aitum Vertical there is a different downstream keyer dock, so don't try to change the existing downstream keyer dock, but open the vertical downstream keyer dock from the OBS docks menu.
