Downstream Keyer
Downstream Keyer 0.4.5
Hey there,
I just took a three-week break from streaming, and now that I’ve updated everything, OBS suddenly shows a bright haze over the screen when the downstream keyer is enabled, which also spreads to the output. I’ve attached two screenshots for comparison. As soon as I disable or uninstall the downstream keyer, the problem goes away. I’ve already completely reinstalled OBS and even Windows (though that was because I was also having BSOD issues, which are now resolved), and I’ve tried uninstalling and reinstalling the Downstream Keyer multiple times, both automatically and manually. I’ve attached both logs, one with and one without the Downstream Keyer.
And ignore the state of the chair xD
  • w- downstream-keyer - faulty 2026-04-16 18-33-25.txt
  • wo- downstream-keyer - not faulty 2026-04-16 18-34-32.txt
Maybe it's me, but I can't get the websocket request to work. I am trying to use the Move Action filter to do a scene select on the downstream, and it didn't work. Tried using streamerbot's OBS raw, and it resulted false.
something is not right with the new plugin, selecting a scene to ib active in the dsk does not stick. I also have vertical installed, are the two plugins conflicting with each other?
ok I figured it out, you need to set the 'Hide After' time to 0ms. that will keep the dsk layer up
downstream-keyer is failing to load for me. On macOS Sequoia 15.7.7 OBS studio 32.1.2
Exceldro can you please look into this, I'm experiencing problems with the new plugging too. When source is visible, the DSK doesn't show until I select the source. I'm using Uno overlay and a "Live" bug and I'm experiencing the same problem on both DSK.
I'm on Mac Tahoe 26.6.2 and OBS 32.2.2
Downstream Keyer has become an absolute staple in our live broadcast workflow. Being able to fire graphics and lower thirds independently of whatever transitions are happening on Preview/Program saves so much headache during fast-paced live shows. Thank you for maintaining this plugin!
This Plugin is broken for OBS 33.0; The layers you create with downstreamkeyer are in the wrong order, and they can't be changed by switching them around. My background now displays on top of everything else because of this. hope it gets fixed soon
@Pizzakoe the plugins works on OBS 33 for me. Are you maybe using an output source that is on top? Or have you set the hide after on a low value that is not 0?
