Window Capture pattern match?
mrzinch
Is it possible to setup a pattern for window capture? Eg. My chrome window is [chrome.exe]: file name (for a photo). I want filename to be something like "whatever*" where it will match any chrome window that starts with "whatever" - is this possible?
I've tried changing the window match priority to match several window names, but this doesn't work. If I open chrome to a different image, it is not found.
Actually, when I close the chrome window and open the file through chrome again, it isn't recognized.. even when the window capture name matches.
I have the same issue. Trying to see if there is a fix for this.
or is it possible to have the ability to use under the Window Match Priority and use of find windows of same executable.
is this maybe a thing that can be easily updated?
thank you,
