Virtual camera format/color problems
frisco
I just upgraded to OBS 26.1 on arch linux, and would like to use the virtual camera feature. Previously, I was using obs-v4l2sink without issue, and it still seems to work. When I disable the v4l2sink extension and start a virtual camera, it sort of works, in that it does feed something to the v4l2loopback driver that I can view, but it looks like the color information or format is somehow getting reported incorrectly, as the image is not right. For example, when I use this hedge as my background, what I get is this:
Though this isn't hard to reproduce, here's a log file in case it helps. Any ideas on how to fix this? Thanks.
