VIDEO ENCODER ISSUE
harshitrajbind
i have a rtx3050 A laptop gpu , it has a video encoder and drivers are upto date , but obs is not showing nvidia encoder in settings , plus , the nvidia app shows that obs has selected nvidia encoder ,i cant understand what to do , obs is upto date , drivers are upto date
nope ,its the gpu
heh no guessing really needed with stuff like this, a log will answer for us
It has. You might think every choice results in a different driver, and if you don't find a 100% exact match for your GPU there isn't a driver, but actually every choice for a RTX GPU results in the same all-in-one driver package. All RTX GPUs no matter if 20xx, 30xx, 40xx, 50xx, desktop and mobile, they all get the same driver package. So simply choose the best match and get the "game ready" driver. The driver installer will scan your system, and if the GPU it finds isn't supported, the driver will refuse to install.
By internal numbers and architecture the
"NVIDIA GeForce RTX 3050 A Laptop GPU"
is variant of
"NVIDIA GeForce RTX 4050 Laptop GPU"
It has less power consumption (because it missing some blocks), so better to look for this RTX 4050 laptop GPU driver rather than RTX 3050.
is variant of
you are technically and mathematically right
i did clean insatllation,still the same
is variant of
didnt solve it
Had a similar issue with an RTX 3050 Ti laptop — OBS wouldn’t show the NVENC encoder even though my drivers were fully up to date. The only thing that fixed it for me was doing a complete driver cleanup using DDU and then installing the Game Ready Driver directly from NVIDIA’s site.
i used nvidia driver installer to do that
would it work?
