Video Capture Device green flickering
MQKhan
I have been trying to use my iPad as a video capture device. I am using a pdf on the iPad and then recording a video lesson whilst writing etc on the pdf. It was working well at first. I was using OBS 32.2.2 (64 bit) and it was running well. Then it started to slow down such that the scroll time lagged, and so did my movements on the camera device. Then a green screen started flickering on the OBS display, but only on the video capture device, not on any other source. I then downgraded to OBS 32.1.2, and tried it again, but the exact same issue happens. I'm not sure why the green flicker happens and how to fix it.
I am currently using a MacBook Pro 2020, macOS 15.7.9 Sequoia.
Log file: https://obsproject.com/logs/uiMXKkdbiHB3EOHv
I have attached screenshots of the video settings, and also of the green flicker on the OBS display.
If anyone has any ideas as to why this is happening and how to fix it please do share. Thank you.
