Versus Ⓡevolution scoreboard
Free Versus Ⓡevolution scoreboard 2.4
Try this example. It is possible to change design with css.
Score by games, total wins and summed scores.
thanks so much for this. i currently have it running now, but im using two instances to show scoreboard theme and sum card which is fine (i hope).
If it works - it's normal!
In my example total scores and number of wins are auto-summed with javascript. But you can do it manual with additional "player" field or with second instance (from different folder with different port)
With next release I will add the "game number" field for much better experience (two player and select game-set number). I think, after New Year hollidays.
Hi again, i have new ideas after using your program for some time now. One of them is to create a hotkey or stream deck multi-action functions to clear scores. This function would benefit us by having one less button to press when we go into a new game as it will automatically reset the score during the multi-action "Blue/Red Win". Last idea is to have a reset score for each player. When we use the autosum, the reset score will reset everything meaning the autosum table gets reset too. i don't know how to separate it from the main program. i tried using different ports but it all linked to the main scoreboard.
For version 2.5 the remote access API will be redesigned. I will try to take these and previously wishes. There will be support for “game sets” with players’ scores being reset when moving to the next set; adding commands to reset a specific player’s score will also not be a problem.
This may have been mentioned before in this discussion, but do you have a design for Brackets?
Each group could be placed visually for people to see before the night starts?
Currently there is no support for the “player bracket”, so it is impossible to display a list of player groups. Only the selected group is transferred to the browser, and not all saved groups.
The idea is interesting, but then groups of players need to be tied to each specific tournament, which means the internal logic will need to be reworked.
Actually I just grasped the concept of Scenes and I think you approached what I wanted with that. Having a scene with 8 players can solve my situation. Now I have to get used to the HTML and CSS to make my ideas work.
Is there a release that could work on MacOS for OBS Studio please ?
Unfortunately, I don't have a Mac OS computer and can't make the corresponding versions. You can use VirtualBox or any other Windows emulator. In the emulator you need to run only Versus and in OBS Studio set the link to the virtual computer. That is, Versus can work on a remote computer, and not on the computer that displays the score.
Try this utility, it seems easier than emulating Windows. Tell us about the result :)
Hello, I have recently downloaded this for live streaming pool matches, can you add an option that doesn't include the scoreboard design, only the numbers and names? and if possible, the style dropdown that usually changes the design will instead change the font?
I would like this option to still include team names, scores, shotclock and if possible another countdown clock that can be used as a match timer similar to ULTIMATE POOL. If too much work I understand, what Im mainly looking for is the option to have no design/background. Thank you for your time, looking forward to hearing back from you
You can customize the appearance of the scoreboard table in any way you want via html/css. You can't make two timers. You can send a link to the appearance of the design that you need. If it possible, I will make you a similar theme.
is it possible to add an option to extend the timer, for example the typical shot time is 45 seconds, but there is an option to extend the shot time by 15 seconds if the players so chooses to. again if too much work I understand. Can you also provide a video or link that shows how to edit the layout/font via html/css
It’s impossible now, but I’ll think about whether it will be possible to change the timer time on the fly, without stopping and restarting.
A brief explanation of how to create themes described in the 'howto.pdf' file.
