"Use Device Timestamps" on "Video Capture Device"
mcglynnj
I would like to suggest porting the "Use Device Timestamps" option that is available for the "Audio Input Capture" audio-only source type to the "Video Capture Device" combi type.
The reason I am suggesting this, is that some media capture devices, especially some ELGATO models, have known issues that can cause audio defects during lengthier streams due to "timestamp drift". Whilst there is a workaround to these glitches by having the audio as a separate source with "Use Device Timestamps" disabled, it may not be preferable for some to have to manage two logical sources for the one physical source.
Man, you're a life saver. i was having troubles with my new elgato because even by manually syncing audio/video, everything was acting weird. now reading this i was able to workaround it by creating a separate audio capture for the same card. thanks a lot!
