Tuna
Tuna v1.9.11
has stopped working with VLC?
I am currently using the latest version of OBS (64bits), VLC(64bits) and Tuna, it is able to get the title of the window but not the song, with media player control it is able to get the song that is playing on Spotify but not with VLC, I have checked with mp3tag and the song has all the data correctly.
Hi, do you have same features with variable time.now inside log mode? I need your best plugin with time when media played. its possible doing this change ?
Hi all,
I want to display what VLC is doing but I need to choose tracks as I go (streaming on Twitch and playing along to tracks). How do I pick songs on the fly and have them playing in VLC itself rather than pumped into a VLC source?
I guess I'm looking for similar to Snip but was hoping I could use Tune as it seems far better integrated and updated.
If I have to edit the VLC source each time I change track then I guess this won't work for me.
Any good ideas?
Cheers,
Rob.
I entered the url http: //xxx.xx.xx.xx: xxxx / status-json.xsl
but he doesn't read anything
What does the server return if you enter http://xxx.xx.xx.xx:xxxx/status-json.xsl in your browser?
Tuna has never had direct support for VLC. Windows Media Control only works with players that make use of the API. Foobar2000 and web browsers do, VLC and MPV don't. You can easily see if a player supports it by checking whether the song shows up in your lock screen or when changing the volume:
Hi all,
Any good ideas?
Cheers,
Rob.
VLC doesn't really offer a good way of retrieving the currently playing song so I don't think there's a good solution.
Hi there, I downloaded Tuna and have gotten most of it up and running. I'm using youtube music. The song title works perfectly fine, but the cover art isn't appearing at all. Is that a youtube music thing or is there something I can do?
thanks,
Brine
Can I ask for or how to add an external site to the script that just uses youtube embeds? The site is without directly linking to it "youtube playlist randomizer bitbucket"
Hello!
I'm new here. Using the "Windows Title" function in Tuna, is there any way to have the song information from a common webpage/website streaming service called "NAXOS MUSIC LIBRARY"?
All I can get Tuna to display is the name of the webpage, but nothing about the song playing itself.
Thanks so much! :)
Is it possible to use the "file_name" variable with video files or is it not possible?
EDIT:
The "title" variable works for me but not the "file_name" variable.
It seems TUNA is no longer working. It still outputs to txt file for file name and time left but no longer displays on the screen, just a green rectangular box. I'm using the VLC option.
https://prnt.sc/-0P6jd87domZ
OBS Version 28.1.2 64bit
Tuna 1.9.1 x64
VLC 3.0.18 x64
EDIT:
Yeah there seems to be an issue with it
Tuna 1.9.1 x64
VLC 3.0.18 x64
Well if it outputs correctly to the text file then it's not an issue on tuna's side
How do we only show a certain key of the json_compact I am wanting to show the title for this json object so I tried {json_compact.title} this didn't work.
Also how come we can't put more then one variable command for spotify! I use to be able to add song name and artist! using this {title} by {file_name} now I get an red error saying "The selected music source does not support one or more of the used format opitions!".
Had a hard drive fail and can't access the files for Tuna to set up the browser source that I'd had beyond what I can do in OBS, uninstalling and reinstalling Tuna didn't recreate them. Any suggestions or a way to get a copy of those files?
