text-pango: multi-language and emoji
text-pango: multi-language and emoji v0.4.1
You system needs to support them (some linuxes may compile system libs without this functionality) and only TTF bitmap fonts are supported. If you are trying to use BDF or any other formats you will need to convert them to TTF first.
Once installed you should see them in the font picker or you can pick the font file yourself.
This is super neat to get emojis to show up in a nice color rendering, thanks! I'm just going to point out one incompatibility which is just random and what I tried to do, when using this together with ScaleToSound, the text source only moves and does not scale
I have M1 Macboom Air
I installed Pango using brew as instructed and the choice to add Pango text was not present.
Please Help!
Hi there! I understand that only TrueType bitmap fonts are currently supported for this plugin.
Is there any chance that the .fnt format (or others of similar function) will be supported in the future?
This plugin no longer works with the new version of OBS Studio 32; it has problems adding a new sources TEXT-PANGO. Does anyone know of an alternative for adding emojis without using the "Segoe UI emoji" font?
> I searched for a few minutes and I think I found an alternative. It might work.
