Question / Help Stream ONVIF using OBS
Hi, thanks for your answer! This works to stream to another PC using Multicast IP. I need rtsp with the same IP as the PC running OBS. Should look like this: rtsp://192.168.1.155:8000/stream . Doese anyone now how to stream rtsp with OBS?
Settings > Output
Output Mode: Advanced
Recording
Type : Custom Output (FFMpeg)
Output type: Output to URL
Container format: RTSP
Settings > Output
Recording
Thanks a loot for showing this but do you have any idea how to write the path for RTSP? I tired: rtsp:// ip of pc:8080/stream and it's not working.
You need to address it to the device that's going to ingest the feed, not the device that's producing it. Where are you sending this stream to?
I'm sending this to a CCTV HIKVISION NVR. I think this NVR doesn't accept to point a stream directly to it's IP. Usually when I ingest cameras, encoders or apps from PCs this devices have their own IP that looks like this: rtsp://192.167.1.51:8080/stream (rtsp:// ip of pc or encoder:8080/stream). Also this URL can be opened with VLC from any computer. This is what I try to achieve with OBS.
