spectralizer
spectralizer v1.3.4
Hi there, having trouble installing this. I downloaded the ZIP file from Github. The folder in the archive is called "spectralizer-master".
In that folder there are the following folders: data, fffftw3, package, src, and then a bunch of random files along with them. I have tried putting the entire folder in my program files/obs-studio/obs-plugins/64bit direcrory, I've tried extracting the folder contents into that directory, but its not showing up as a source in OBS.
I have read the installation directions 100x but there is no "plugins" folder in the ZIP file I download. Please tell me what I am missing - thanks kindly!
You downloaded the source code not the plugin
Hi! I can't install spectralizer on macos.
I have Mac Os High Sierra and OBS Studio 24.6 version.
When I want to install spectralizer on my OBS Studio, I runned command install-mac.sh, but it said me the follow message:
"Creating plugin folder
Moving plugin over
mv: rename plugin/* to /Users/un4g1v3n/Library/Application Support/obs-studio/plugins/spectralizer/*: No such file or directory
Done!"
When I open the OBS Studio don't show in sources, I try to copy manually in the application plugin directory and dont works... : /
Someone can help me?
Thank you in advance and sorry for my bad english.
Best Regards from Spain.
I'm having the same problem as UN4G1V3N! After hours of trying to get it installed. I finally do, but now I can't find it in Tools or in Sources. I can't figure out how to add it in either.
09:15:46.347: CPU Name: Intel(R) Core(TM) i5-6287U CPU @ 3.10GHz
09:15:46.347: CPU Speed: 3100MHz
09:15:46.347: Physical Cores: 2, Logical Cores: 4
09:15:46.347: Physical Memory: 8192MB Total
09:15:46.347: OS Name: Mac OS X (NSMACHOperatingSystem)
09:15:46.347: OS Version: Version 10.15.4 (Build 19E266)
09:15:46.347: Kernel Version: 19.4.0
09:15:46.362: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
09:15:46.363: Portable mode: false
09:15:46.459: OBS 24.0.6 (mac)
09:15:46.459: ---------------------------------
09:15:46.460: ---------------------------------
09:15:46.460: audio settings reset:
09:15:46.460: samples per sec: 44100
09:15:46.460: speakers: 2
09:15:46.462: ---------------------------------
09:15:46.462: Initializing OpenGL...
09:15:46.492: Loading up OpenGL on adapter Intel Inc. Intel(R) Iris(TM) Graphics 550
09:15:46.492: OpenGL loaded successfully, version 4.1 INTEL-14.5.22, shading language 4.10
09:15:46.589: ---------------------------------
09:15:46.589: video settings reset:
09:15:46.589: base resolution: 1440x900
09:15:46.589: output resolution: 1152x720
09:15:46.589: downscale filter: Bicubic
09:15:46.589: fps: 30/1
09:15:46.589: format: NV12
09:15:46.589: YUV mode: 601/Partial
09:15:46.589: NV12 texture support not available
09:15:46.590: Audio monitoring device:
09:15:46.590: name: Default
09:15:46.590: id: default
09:15:46.590: ---------------------------------
09:15:46.603: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
09:15:46.616: os_dlopen(libpython3.7m.dylib->libpython3.7m.dylib): dlopen(libpython3.7m.dylib, 257): image not found
09:15:46.616:
09:15:46.616: [Python] Could not load library: libpython3.7m.dylib
09:15:46.699: No blackmagic support
09:15:46.792: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
09:15:46.900: [obs-browser]: Version 2.7.16
09:15:46.935: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib, 257): image not found
09:15:46.935:
09:15:46.935: Couldn't find VLC installation, VLC video source disabled
09:15:46.936: Ignoring old obs-browser.so version
09:15:46.936: ---------------------------------
09:15:46.936: Loaded Modules:
09:15:46.936: vlc-video.so
09:15:46.936: text-freetype2.so
09:15:46.936: rtmp-services.so
09:15:46.936: obs-x264.so
09:15:46.936: obs-vst.so
09:15:46.936: obs-transitions.so
09:15:46.936: obs-outputs.so
09:15:46.936: obs-libfdk.so
09:15:46.936: obs-filters.so
09:15:46.936: obs-ffmpeg.so
09:15:46.936: obs-browser.so
09:15:46.936: mac-vth264.so
09:15:46.936: mac-syphon.so
09:15:46.936: mac-decklink.so
09:15:46.936: mac-capture.so
09:15:46.936: mac-avcapture.so
09:15:46.936: linux-jack.so
09:15:46.936: image-source.so
09:15:46.936: frontend-tools.so
09:15:46.936: decklink-ouput-ui.so
09:15:46.936: coreaudio-encoder.so
09:15:46.936: advanced-scene-switcher.so
09:15:46.936: os_dlopen(../obs-plugins/obs-browser->../obs-plugins/obs-browser.so): dlopen(../obs-plugins/obs-browser.so, 257): image not found
09:15:46.936:
09:15:46.936: ==== Startup complete ===============================================
09:15:46.967: Switched to Preview/Program mode
09:15:46.967: ------------------------------------------------
09:15:46.970: All scene data cleared
09:15:46.970: ------------------------------------------------
09:15:47.029: coreaudio: device 'Built-in Microphone' initialized
09:15:47.058: [Media Source 'Media Source']: settings:
09:15:47.058: input: /Users/jamesburke/Music/iTunes/iTunes Media/Music/(Soundtrack)/Soundtrack BRD/05 Prior To A Prayer (Soundtrack).mp3
09:15:47.058: input_format: (null)
09:15:47.058: speed: 100
09:15:47.058: is_looping: yes
09:15:47.058: is_hw_decoding: no
09:15:47.058: is_clear_on_media_end: yes
09:15:47.058: restart_on_activate: yes
09:15:47.058: close_when_inactive: no
09:15:47.661: coreaudio: device 'Built-in Microphone' initialized
09:15:47.673: Video Capture Device: Selected device 'FaceTime HD Camera (Built-in)'
09:15:47.676: Video Capture Device: Using preset 1280x720
09:15:47.705: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Audio Input Capture)
09:15:47.705:
09:15:47.821: Switched to scene 'Testing'
09:15:47.823: ------------------------------------------------
09:15:47.823: Loaded scenes:
09:15:47.823: - scene 'Pre-Show':
09:15:47.823: - source: 'Lighthouse' (image_source)
09:15:47.823: - source: 'Countdown' (text_ft2_source)
09:15:47.823: - filter: 'Color Correction' (color_filter)
09:15:47.823: - source: 'Media Source' (ffmpeg_source)
09:15:47.823: - scene 'Testing':
09:15:47.823: - source: 'testing' (image_source)
09:15:47.823: - scene 'Service':
09:15:47.823: - source: 'Video Capture Device' (av_capture_input)
09:15:47.823: - source: 'Audio Input Capture' (coreaudio_input_capture)
09:15:47.823: - source: 'Group' (group)
09:15:47.823: - source: 'Color Source' (color_source)
09:15:47.823: - source: 'Sermon Title' (text_ft2_source)
09:15:47.823: - scene 'Service 2':
09:15:47.823: - scene 'Post-Show':
09:15:47.823: - source: 'Thank You' (text_ft2_source)
09:15:56.751: ==== Shutting down ==================================================
09:15:56.756: Switched to scene '(null)'
09:15:57.500: All scene data cleared
09:15:57.500: ------------------------------------------------
09:15:57.572: Freeing OBS context data
09:15:57.575: [Scripting] Total detached callbacks: 3
09:15:57.580: == Profiler Results =============================
09:15:57.580: run_program_init: 2080.04 ms
09:15:57.580: ┣OBSApp::AppInit: 6.375 ms
09:15:57.580: ┃ ┗OBSApp::InitLocale: 3.106 ms
09:15:57.580: ┗OBSApp::OBSInit: 1764.46 ms
09:15:57.580: ┣obs_startup: 16.312 ms
09:15:57.580: ┗OBSBasic::OBSInit: 1651.6 ms
09:15:57.580: ┣OBSBasic::InitBasicConfig: 0.253 ms
09:15:57.580: ┣OBSBasic::ResetAudio: 0.113 ms
09:15:57.580: ┣OBSBasic::ResetVideo: 129.69 ms
09:15:57.580: ┣OBSBasic::InitOBSCallbacks: 0.022 ms
09:15:57.580: ┣OBSBasic::InitHotkeys: 0.082 ms
09:15:57.580: ┣obs_load_all_modules: 346.207 ms
09:15:57.580: ┃ ┣obs_init_module(advanced-scene-switcher.so): 0.259 ms
09:15:57.580: ┃ ┣obs_init_module(coreaudio-encoder.so): 0.024 ms
09:15:57.580: ┃ ┣obs_init_module(decklink-ouput-ui.so): 0.676 ms
09:15:57.580: ┃ ┣obs_init_module(frontend-tools.so): 5.102 ms
09:15:57.580: ┃ ┣obs_init_module(image-source.so): 0.01 ms
09:15:57.580: ┃ ┣obs_init_module(linux-jack.so): 0.007 ms
09:15:57.580: ┃ ┣obs_init_module(mac-avcapture.so): 67.689 ms
09:15:57.580: ┃ ┣obs_init_module(mac-capture.so): 0.007 ms
09:15:57.580: ┃ ┣obs_init_module(mac-decklink.so): 0.087 ms
09:15:57.580: ┃ ┣obs_init_module(mac-syphon.so): 0.005 ms
09:15:57.580: ┃ ┣obs_init_module(mac-vth264.so): 89.047 ms
09:15:57.580: ┃ ┣obs_init_module(obs-browser.so): 0.585 ms
09:15:57.580: ┃ ┣obs_init_module(obs-ffmpeg.so): 0.044 ms
09:15:57.580: ┃ ┣obs_init_module(obs-filters.so): 0.021 ms
09:15:57.580: ┃ ┣obs_init_module(obs-libfdk.so): 0.003 ms
09:15:57.580: ┃ ┣obs_init_module(obs-outputs.so): 0.01 ms
09:15:57.580: ┃ ┣obs_init_module(obs-transitions.so): 0.01 ms
09:15:57.580: ┃ ┣obs_init_module(obs-vst.so): 0.031 ms
09:15:57.580: ┃ ┣obs_init_module(obs-x264.so): 0.005 ms
09:15:57.580: ┃ ┣obs_init_module(rtmp-services.so): 2.244 ms
09:15:57.580: ┃ ┣obs_init_module(text-freetype2.so): 0.024 ms
09:15:57.580: ┃ ┗obs_init_module(vlc-video.so): 0.254 ms
09:15:57.580: ┣OBSBasic::ResetOutputs: 17.749 ms
09:15:57.580: ┣OBSBasic::CreateHotkeys: 0.101 ms
09:15:57.580: ┣OBSBasic::InitService: 0.445 ms
09:15:57.580: ┣OBSBasic::InitPrimitives: 0.13 ms
09:15:57.580: ┗OBSBasic::Load: 858.984 ms
09:15:57.580: obs_hotkey_thread(25 ms): min=0.293 ms, median=0.571 ms, max=4.799 ms, 99th percentile=1.969 ms, 100% below 25 ms
09:15:57.580: audio_thread(Audio): min=0.011 ms, median=0.059 ms, max=32.373 ms, 99th percentile=0.669 ms
09:15:57.580: obs_graphics_thread(33.3333 ms): min=0.076 ms, median=34.753 ms, max=764.38 ms, 99th percentile=82.914 ms, 35.6846% below 33.333 ms
09:15:57.580: ┣tick_sources: min=0 ms, median=0.022 ms, max=764.263 ms, 99th percentile=0.444 ms
09:15:57.580: ┣output_frame: min=0.031 ms, median=0.216 ms, max=45.225 ms, 99th percentile=1.777 ms
09:15:57.580: ┃ ┗gs_context(video->graphics): min=0.031 ms, median=0.215 ms, max=45.224 ms, 99th percentile=1.776 ms
09:15:57.580: ┃ ┣render_video: min=0.012 ms, median=0.192 ms, max=39.971 ms, 99th percentile=0.934 ms
09:15:57.580: ┃ ┃ ┗render_main_texture: min=0.01 ms, median=0.187 ms, max=39.965 ms, 99th percentile=0.929 ms
09:15:57.580: ┃ ┗gs_flush: min=0 ms, median=0 ms, max=5.51 ms, 99th percentile=0.974 ms
09:15:57.580: ┗render_displays: min=0 ms, median=34.24 ms, max=108.42 ms, 99th percentile=73.62 ms
09:15:57.580: =================================================
09:15:57.580: == Profiler Time Between Calls ==================
09:15:57.580: obs_hotkey_thread(25 ms): min=25.317 ms, median=27.827 ms, max=36.234 ms, 2.00501% within ±2% of 25 ms (0% lower, 97.995% higher)
09:15:57.580: obs_graphics_thread(33.3333 ms): min=2.337 ms, median=35.801 ms, max=764.387 ms, 25.4167% within ±2% of 33.333 ms (16.25% lower, 58.3333% higher)
09:15:57.581: =================================================
09:15:57.586: Number of memory leaks: 0
Moving plugin over
Done!"
I'm responding to save the Dev a little trouble since I made the same mistake and figured it out.
You're trying to download the source code. Instead, you want to click the 'go to download' link there and install the one matching your OS.
duplicate the downloaded organizer and put it in the envelopes of the modules and nothing I additionally reorder the records and glue them in the two envelopes and nothing At that point I don't perceive how to initiate the module and the properties window will show up for setting it up
would you be able to support me
Moving plugin over
Done!"
Worest plugin documentation.
Hey there. I was able to get this installed on my Mac by following the steps, first installing Brew, and then using the script to install fftw3 and finally the spectralizer. I got it working in OBS. Now I'd like to get this working in Streamlabs OBS, please! They just released a version for Mac. Simply creating an identical spectralizer folder with the "bin" and "data" folders inside into the /$USER/Library/Application Support/slobs-plugins/* doesn't work.
Am I right that Streamlabs OBS is built on an OBS framework and is the same in many, many ways?
Any suggestions or workarounds, please?
How do you set this up in the first place? (I really tried every way I could) Is there a tutorial video somewhere?
Solved!! Thank you so much!
Working fine!!
Love this plugin! One weird problem I've encountered just today though...
The spectralizer is not as responsive to video files through the VLC source, as it was a few days ago. It is refreshing only once every 0.5 seconds kinda thing, whereas when I initially tested it, it would be immediately responsive to the audio source with no lagging etc.
Any ideas to fix this would be amazing! Cheers
I followed the directions and feel successfully updated the obs plugin files correctly. The audio visualizer shows up as a source, but when I click ok to add it, it crashes OBS. Attached is the log. Any help would be appreciated!
For the Mac install instructions...
2. Copy over the folders "bin" and "data" from the folder "plugin" from this zip file:
$ mv plugin/* "/Users/$USER/Library/Application Support/obs-studio/plugins/spectralizer"
There is no Bin folder? Only Data. Please advise.
hi, i used spectralizer v1.2 for mac for a while tonight with OBS v25.0.8 on mac mojave 10.14.6. very cool plugin, thank you for that.
then i went to try out another plugin - Tuna. the Tuna developer hasn't released a new version and has on their page to use the older version. installed it. couldn't get it to work AND it stopped spectralizer from working.
so, i tried many reinstalls and mac restarts and even deleted Tuna, still can't get spectralizer to work again.
it shows up as a source but no audio from any source triggers the metering/visuals either in the overlay or in the source selection popup.
i can hear & see the audio coming into OBS on the audio mixer meters no problem. spectralizer is not recognizing the audio source.
tried re-installing homebrew and spectralizer, everything seems to be in the right place.
help?
Is there any possibility to use this with asio? Can't seem to get it working. Or maybe a workaround? My audio card it asio only.
Hi guys, it's my first post here. Itried to read about my problem with the plug-in but no way.
I didn't manage to see spetralizer on the list of sources
This is my Install.mac.sh:
#!/bin/sh
echo "Checking for brew.."
if ! [ -x "$(command -v brew)" ]; then
echo 'Error: brew is not installed!'
echo 'Install brew from https://brew.sh'
exit 1
fi
echo "Checking for fftw..."
if brew ls --versions fftw > /dev/null; then
echo "fftw is already installed"
else
echo "Installing fftw"
brew install fftw
fi
echo "Uninstalling old version"
rm -rf "/Users/$USER/Library/Application Support/obs-studio/plugins/spectralizer"
echo "Creating plugin folder"
mkdir -p "/Users/$USER/Library/Application Support/obs-studio/plugins/spectralizer"
echo "Moving plugin over"
echo "Done!"/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install.sh)"
I also attached my log if needed.
I hope you guys can help me! Thanx in advance!
For the life of me I cannot get this plugin to work. Using OBS 25, followed instructions, yet nothing. Files show UP in my obs-plugins folders yet nothing shows up in sources. Installation IS simple, but it just does not work. I am a PC noob (recent machead, windows is frustratingly new to me) so any help appreciated.
Trying to install on a Mac and I don't understand the first step of the installation instructions: Install fftw3 over brew. Is there an app called "fftw3 over brew"? If there is, I can't find it. Or do I install "brew" and then "fftw3" over it? If so, I'm not quite sure how to install one application over another.
The rest of the instructions make sense and I've downloaded the correct file, just want to get this first step right before moving on.
