sound issue
Joelzstuff
How do I fix this sound issue. Everything was working great until I downloaded the new OBS 30.0.0. My sound sounds perfect on my headset but it sounds like this in the recording. I have windows 11 operating system.
Thanks everyone!
There, Thanks for letting me know
Works now!
Sounds like a similar problem that someone posted last week. My answer to that was:
Are you using the Application Audio Capture source? It does that. Don't use it for anything critical.
Instead, use the older method of capturing the *entire* output of a selected device, and controlling by other means, what goes to that device. If you need to add a device, so you can do that without wrecking something else, then add a device. A cheap USB thing that doesn't wire to anything, or a virtual speaker; either way works.
if you still have some issues:
And, please, describe step by step what you doing, what is wrong, and when it goes wrong.
What you have set in shared mode for the audio device (in Windows , Sound > Playback > Speakers > Properties > Advanced > Default Format)?
If nothing helps, you can try to install previous version of OBS and continue to use it.
All OBS releases (under the "Assets" spoiler):
