Free Snaz [Deleted]
Status
Not open for further replies.
Hello, I love the program, but I do have an issue. Minor issue, but when playing music, the text display will sometimes not work. I usually have to either restart snaz or pause, then play to fix. Not sure if bug, or just my comp being....my comp. Any feedback would be awesome.
I would call that a big issue :)
However, there are no bug reports on that, the best way to post bugs or problem is on the next page.
https://github.com/JimmyAppelt/Snaz/issues
Also consider to post more details, in case of a bug i have to be able to replicate the issue. Like for example, I have to know what kind of player you are using. etc.
Kind regards
Jim
Would it be possible to add a button to the Text Line Changer so you can force a line of text to switch instead of waiting on the timer?
Thank you for creating this! It is beyond awesome! It combines virtually everything I've been looking for into one interface.
Are you able to allow for all caps for artist/song text? It seems current output is limited to upper/lower case. Also, would you be able to add the ability to strip data (text) from XML files? This might be asking too much.
Keep up the great work!
It seems for me snaz might lag my stream after a couple hours. Anyone else have this issue and/or know how I can fix it?
Hey Yachak,
first of all I would like to thank you for great app. And also I would like to ask you, if you planning to add support for AIMP3.
Thx for reply.
Need some help in getting the JSON Playing Now function to work. I'm not sure where to place files and which one to point to in OBS.
Right now I have a folder called "PlayingNow".
In there, I have:
index.html
track-info.json
css/style.css
js/playing-now.js
The contents in the HTML, CSS and JS file were taken from here: https://github.com/JimmyAppelt/Snaz/wiki/Json---HTML-CSS-JS-(Example)
Then, I went into Snaz and as instructed, hit File -> Settings -> Playing Now
And changed the location of the JSON file to where my folder is.
In OBS, I've tried adding browser sources pointing to both index.html and track-info.json
None show anything...
I'm sure I'm missing something. Help?
Any chance of being able to change the location the text files are generated? atm i use batch files to do what snaz does, only snaz is a lot better, i like all those text files to go into my RamDisk which gets wiped every reset and doesnt cause any HD activity, esp something like a time being updated pretty frequently.
Hi, is there a solution to the iTunes exception error, Error HRESULT E_FAIL? It happens whenever I attempt to open iTunes using Snaz.
I've tried googling and searching this forum for a solution, but nothing has come up. Please help.
As of today starting with this error.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
Newtonsoft.Json.JsonReaderException: Unexpected character encountered while parsing value: <. Path '', line 0, position 0.
at Newtonsoft.Json.JsonTextReader.ParseValue()
at Newtonsoft.Json.JsonTextReader.Read()
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.ReadForType(JsonReader reader, JsonContract contract, Boolean hasConverter)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
at SpotifyAPI.Web.Auth.ClientCredentialsAuth.DoAuth()
at Snaz.Classes.SpotifyManager.RequestAccessToken()
at Snaz.Forms.MainForm.cg(Object A_0, EventArgs A_1)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2633.0 built by: NET471REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Snaz
Assembly Version: 1.12.6.0
Win32 Version: 1.12.6.0
CodeBase: file:///C:/Snaz/Snaz.exe
Win32 Version: 4.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SpotifyAPI
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Snaz/SpotifyAPI.DLL
Newtonsoft.Json
Assembly Version: 9.0.0.0
Win32 Version: 9.0.1.19813
CodeBase: file:///C:/Snaz/Newtonsoft.Json.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.7.2612.0 built by: NET471REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Windows.Forms.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll
AutoUpdater.NET
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/Snaz/AutoUpdater.NET.DLL
TwitchApi
CodeBase: file:///C:/Snaz/TwitchApi.DLL
System.Net.Http
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Status
