SuttySmash
Hey all,
I'm at my wits end here trying to figure out what's going on here. Two days ago, I was streaming Jedi: Fallen Order perfectly fine and seamlessly; absolutely no issues and the output was buttery smooth...you could spread that beast onto toast. The game is set to cap itself at 60FPS and I was playing in fullscreen when everything was working fine. Game Capture never worked for some reason (black screen), so I would use Window Capture. I updated my GPU driver to the latest version yesterday, and that's when things got all crazy. Window Capture on fullscreen would freeze on the very first frame of the output. I set the game to Borderless Windowed and it would capture, but the output was dropping frames like crazy. I tried adjusting graphics settings, setting OBS to high priority in tasks, and updating OBS to the latest version. After none of this worked, I tried rolling back the drivers, but I've been getting the same issues. None of this stuff needed tweaking or modifying prior to the drivers. I started a clean install of the old driver before I left for work this morning, but this has been a thorn in my side and on my mind as I'm not able to figure it out on my own (just as frustrating).
Smooth Stream
https://www.twitch.tv/videos/513420283
Janky Stream
https://www.twitch.tv/videos/513833685
I've attached the OBS logs from my testing after realizing there was an issue. Any help here would be appreciated, I'm struggling to figure this out.
Regards,
Sutty
Smooth Stream
Janky Stream
Regards,
Sutty
