Question / Help Settings
Your CPU might not handle 1080P@60FPS recording while streaming certain games... Tone it down to 1080@30FPS or 720P@60FPS and try again.
Unfortunately your system is really underpowered for streaming/recording. You can try using the recording quality preset under Settings > Output (switch to Simple mode) and downscaling your output resolution under Settings > Video, but the results probably won't be very good until you purchase better hardware.
  • Computer Type - Desktop Tower
    Processor Type - Intel Core i5
    Processor Model Number - 4460T
    Processor Memory Cache - 6
    Processor Max. Clock Speed (GHz) - 2.7
    RAM (GB) - 8.0
    HDD Storage - 2TB
    Total Storage - 2TB
    Graphics Processor - AMD Radeon R5 330 2GB DDR3 FH GFX [Aries-V1 2G]
    Graphics Memory - 2GB
    USB 2.0 Ports - 4
    USB 3.0 Ports - 2
    USB Ports - 6
    Optical Drive - DVD Super Multi
    Wi-Fi - Yes
    Operating System - Windows 10
    What will this computer do? will it be able to record really smoothly like some youtubers?
