Replay Source
Replay Source 1.8.2
@dungi You can also combine the load hotkey with the switch to replay scene hotkey to get instant replay.
Let me know if there are other replay use cases you want a same kind of explanation video for.
I may be doing something wrong while installing this plugin because it doesn't appear as a source in my menu. I dropped the files in this location
C:\Program Files (x86)\obs-studio\obs-plugins\64bit
Is that correct? Is it maybe a 32 bit plugin? My OBS version is 21.1.0 64bits
@Zapa the location is correct but you need OBS version 22 or higher
Ah, ok. Thks. It seems the update checker is not working because nothing happens when i select it in OBS. Indeed everything worked!
I have a question, though. I want to save all the replays in different files. Is there a way to do this automatically when we load a replay or do we have to combine different hotkeys to load and save the replay? I set the same hotkey for both but then OBS froze so I guess they have to be different but it would be cool if you could do that automatically.
Thanks for your work and your support! :)
I use same, but you have to wait a time bettwen differents savings... if not it crash.. but the saving files in my case I don't know why, are unusable...
It works for me now, it is great. THank you for this awesome Plugin. I use it to instant replay some of my gaming footage. They love it. But i can only recommend to use this with 32gb of ram. But thats fine i guess. :) Super Work!
For some people (me included) the save is working, for others it is not working. I still have not been able to track down the problem. If you have a crashlog please post it here or direct message it to me so I can get a better understanding of the poblem.
When I close the OBS, something breaks.
I don't know what to do about it
To make it work, I have to reinstall OBS and add the plugins again
(Edit) If I close OBS with the "Exit" button instead of the normal Windows button, it doesn't break.
@srdrabx That crash log does not seem related to the replay source. You can verify that by removing the plugin and see if that fixes your crash.
It crashes in clearing a transition, so maybe check the transitions you use.
I think I've managed to replicate the errors.
The 1st, the replay does not begin and returns directly to the next scene
I think to fix it, I just have to put the properties back in the source.
The second error, I think it's like you said, because of the transitions, I'm not sure, but I think it's because the transition is in MOV, because I just had this error when I added the transition.
I have spent a day or so attempting to get this to work. Does that work in conjunction with the Replay Buffer settings in OBS? I followed your tutorials and instructions but still get nothing.
@BeardedWonder This plugin does nothing with the replay buffer settings in OBS.
Did you check if the source/scene you are trying to capture has the correct replay filter added with the correct settings?
I got this to work--sort of. What I want to do-Use cam 2 to get a replay of racers going over finish line. At this point I only need it to play once. After it has played once, switch to cam 1. I set this up for test purposes using an existing video as my source. It works fine except- when I switch back to the OpenerVideo (cam2), it plays the replay again. Can't figure out what I'm doing wrong. https://youtu.be/IQ_1FUWtL7I
A second part to this is I can foresee once I start doing this, there may be a need to playback a recorded replay ie: replay 1, replay 2. I thought that was what the directory was for but there is nothing in there
  • 2019-03-09 08-53-03.txt
1. Is there a way to trigger the replay action and automagically play the replay scene? I have a 4 way xkeys stick on my camera that I use to switch cam1 and cam 2. With the current 2 keys to press, I can only set replay for 1 camera.
2. Seems I saw someplace to make donations?
