Replay Source
Replay Source 1.8.2
I have the Maximum Replays set to 1...I expected it to then overwrite that replay each time the video source was active again. It does not appear to function that way, so I'd have to clear the replay each time? I feel like that should be a setting. Seems to work amazing other than this.
When using the plugin average time to render frame jumps from 11 +/- 6 ms to 26 +/- 10ms. Is there any settings that can be changed to lower this average time to render? After awhile of usage OBS Starts to slow down to a crawl and maybe even crashes. I have a good amount of plugins but replay source is the only one that really makes frame rendering jump very high.
One issue I'm having is...I set the duration of the replay to 10 seconds (10000ms), but no matter what I do, it only gives a 5 second replay. Am I missing something here? Everything below the scrolling in the picture is at default.View attachment 106701
For a few days now, the same thing has been happening to me. First, the repetitions went with jumps. I had to close and reopen the program to get them to look normal. However, when adding a new repeat source, the number of seconds you set is always displayed as 5.
Were you able to find the solution?
im experiencing the same issue but with no crashs. i rund 5 ndi cameras and a second obs instance with 3 to 5 ndi cameras. all cameras have the replay source and an always running replay scene. obs cant keep 60 fps constant and when hitting save replay it drops to 30 to 40 and stays sometimes there until i save antother replays. also i have weird issues with flv that sound is not sync (prob due to not having 60 fps). @Exeldro are you accepting polar.sh or ko-fi or any other way, to get this fixed with a "bounty". Would love to have stable replay source and encoder settings for replay saving. i tried to switch to source record but with 10 cameras on one machine its breaking my 4070 ti + ryzen 9 5950x 16 core
still the best replay plugin on the market, keep up the great work exeldro
Unfortunately I wasn't :(
Two problems
- when I start to save clips, a few minutes the new clips are slowdown. It´s only in the image, the sound goes in normal speed.
- In the OBS' new version 30.2.3, the program crashed when deletes the Replay Source.
Two problems
I found the first problem, it happen when the streaming have a different resolution than the program's resolution.
This has been happening more and more frequently with my upgrades over the last few months and now my memory usage is capping out rendering my stream useless.
@Exeldro can you look at this plugin again? Quite a few of us are having major issues. Thanks!
@Exeldro I'd like to bring this issue to your attention again. I was contacted by a member of this group who was having the same issue I had to see what my work around was and I created a video for him to see my settings and work around. This seems to have something to do with the Elgato Cam Link 4K and I'd be happy to help debug or test any methods on my end if you'd like the help. Here's the video I put together:
Hi guys
I was woundering if there is a way to when u set it to more then 1 replays lets say 5 and have it load and play nr 3 directly with a commad lets call it play3
@Exeldro my question above possible with ur plugin somehow getting to one of the replays so its plays a specific one .since i saw if i understud it right u can get the amount in text if i also undestod right u can also see witch one is loaded .
This is a great pluggin .
Only thing that would make it better is if u pic the amount of reply u want and slots would appere with the same amount .and the fuction i was just talking about and maybe save specific clip number .
Any how keep up the great work its trully awsome
Want more futures, sports futures. Now it is used in sporting events. For example, cricket, football, tennis etc. So more sports futures like vmix instant reply are needed
