NicOnAcid Member Mar 7, 2016 #1 Hi, is there a Workaround to rename the Audiodevices? I use several Devices. Didn knowing wich one is for what is little bit annoying. Attachments Unbenannt.PNG 9.7 KB · Views: 61
Gol D. Ace Member Mar 9, 2016 #2 You would need to use the Audio Input / Output Capture Sources for that currently. Note that you will have to manually add them to all scenes.
Suslik V Active Member Mar 9, 2016 #3 when add them throught the scenes use clone option: 'Add Existing' and disable all devices at Settings>Audio (to remove double).
