Question / Help Recording Problems
I am using obs for Mac (always the latest version)
I am trying to record a game called geometry dash
I have set all the video size to 1080p and 60fps and bitrate 24000 using the apple vt h264 encoder
When I play the game and recording the obs window says it is running at 60fps and I also play the game at 60fps but the mp4 that it recorded is very low quality with about 15fps...
Notes:
  • I am using display capture instead of syphon inject and game capture
  • My Mac is the basic late 2013 21.5 inch iMac ( Iris Pro Graphics ) (It can run some heavy games on high at 900p and it is recording everything perfect when using another recorder on windows via bootcamp including geometry dash with 60fps)
Thanks
Like @Narcogen said, there's no reason to use the Apple VT encoder. It's basically a broken encoder, meant for testing. Better to use CRF and set the value from 15-23(lower=higher quality).
