So when i try to clip replay buffer it sometimes works perfectly but most of the times my clip is ruined because video is just like 1 frame for 10 seconds(audio is fine).
My settings: https://www.youtube.com/watch?v=ONdEzCMRS2c&ab_channel=Franz
My specs: 1660 Super, i-5 10400F, 16gb Ram
I always minimize Obs window on the second monitor because i got more fps (if that is the problem)
I attached all my files i dont know how you understand, but if you need it its there
Thanks for your help
