Perfect Timer Build 1
Urz
Urz submitted a new resource:
Perfect Timer - Advanced timer tool with direct source update and automatic scene transition
Perfect Timer is a timer companion designed to be used with OBS.
Features
— Unlimited timers
— Update text sources directly via websocket
— Automatic scene change on timer start and/or end via websocket
— Traditional text file output
— Early warning color change
Changelog
Build 1 (2020-06-24)
— Initial release
Thank you for this great timer!
I've had some difficulty using the timer because my windows system text settings are 150% and this breaks the dialog text in the menus.
Are you aware of a work-around for this problem, or are there enhancements that can be made to your useful tool?
Thank you.
P.S. Is there any additional documentation or tutorials associated with your plug-in?
