OBS Zooms for no reason
PauBa
I really hope that someone out there can help me!
Recently OBS has started zooming in for no reason and it’s annoying as you might imagine!
When I’m watching any program that has a banner across the bottom of the screen, it cuts the banner off and if there is additional info on the screen on the side, it cuts that off as well!
I’m running Windows 11 and just a generic video capture device. The device just send the picture that’s being displayed on the screen to my OBS. I’m just using the OBS as a PVR in a sense. Sorry for the length of the video but I needed to demonstrate what's happening.
I have tried the everything I've found thru Google including changing screen resolution and fit to screen with no success.
-Paul
Paul, try adding the capture device as an existing source in a new, empty scene and make a short recording while the ticker is visible. If the ticker comes back, check the original scene’s Edit Transform window for crop values. If both recordings cut off the same text, compare them with the TV picture from the same feed before changing the canvas again.
Thank you for your suggestion. Unfortunately, it didn’t work. I went as far as uninstalling OBS and reinstalling, still same issue!
Copied the OBS folder from another laptop where it worked as designed and that didn’t work. I’m at a loss :-(
I assume you're talking about this:
That is very strange. Does your generic video capture device have any sort of auto-focus/AI? Does this happen if OBS is closed and you use the Windows Camera app to view the source?
If this is happening in OBS with a clean Scene with only the video capture device and no filters, but doesn't happen in the Windows Camera app, please provide a log.
Here is my log file: https://obsproject.com/logs/z2VxBJAgISxBLWT2
I’ve been using this same laptop and the same video capture card for nearly one year and this issue just started happening a few days ago. I haven’t installed any new apps or hardware. I have the same video capture card on a different laptop (family member) and they are not facing this issue.
The OBS version is too old.
More important, the log file have no output session. Please provide the log file from the moment the issue happened.
Also, old hardware eventually fails.
That’s frustrating after a year of it working fine. If you haven’t already, try your actual capture card on the laptop where the picture looks right, keeping the HDMI cable and TV feed the same. If the full ticker comes back, that points to something on your laptop.
The reason this is an older version is, I uninstalled OBS any thought I'd try an older version first.
I will swap out the capture card with the other one that's known to be working.
I'll upload the latest log files before I decide to do a fresh install of Windows if nothing else works!
Thanks for your help.
-Paul
