Question / Help OBS will not run on MacBook
AndyA
Hopefully someone can help? OBS was downloaded about a week ago and worked when first installed. However this evening it will not run at all and creates a log file with the option to send to Apple. As far as I know i have not added or changed anything on the Mac. I did notice that when trying to run the webcam flashed on and then off, Do not remember seeing any activity since. I have subsequently deleted the app and reinstalled without any success. If anyone can show me how to resolve this, it would be greatly appreciated. MacBook is a 13" MacBook Pro - Retina screen running MacOS Sierra 10.12. Many thanks in advance.
1. Close OBS.
2. Open finder and hit Cmd+Shift+G > ~/Library/Application Support/
3. Find the obs-studio folder and delete it.
4. Open OBS again.
Hi, thank you for the fast reply, did as you instructed but i'm afraid it still will not run? Message is 'OBS quit unexpectedly' very time I try to run the program? When trying to re-run, the above folder is not created, This is very frustrating.
