Bug Report OBS Studio not using my Full Upload Speed!
Siebakk
I was using the same settings of my stream for a Year and had no problems that i could't fix.
My Internet speed is 30/6 Mbs
After last weekend my OBS won't stream above 3000 kb/s and often drops to 0 kb/s (I am streaming on twtich with 4500/5000 kb/s with no problem until now)
I tried Multiple Platforms and the problem is still there like restream
I have contacted my provider and they are not seeing any issue on their side. Upload and Download Speed is FINE!
they even boost my internet to 70/70 Mbs and even i get drop bitrate
Both PC have same specs.
i5 8600k
GTX 1070ti
16gb
  • 2020-02-25 14-07-09.txt
Use TwitchTest. Generic speedtest results are not relevant to streaming performance.
17:08:00.547: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 184135 (31.2%)
If the problem is not with your local computer, its networking hardware and drivers, local cabling, router, then it is with your ISP and you should contact them.
ye like i write up i connent with they are not seeing any issue on their side they even boost my internet to 70/70 Mbs and even i get drop bit
