OBS settings using Blackhole
mark_urir
Can somebody help me with this, please? I cannot get my UX2 microphone to work on my OBS using my Mac Studio M2 Max (Ventura 13.5.2). I have installed blackhole but don't know how to work on creating aggregate/multi-output device. I have attached the settings I used but it is not working. I would appreciate your help. thank you very much!
It's only OBS that I'm having problems with. I can use my condenser mic connected to my line 6 UX2 interface for zoom, garageband, final cut pro. but OBS I can record the audio of the screen but could not work the microphone. Do I have to select the audio encoders within OBS?
You have mic in global settings set to "blackhole" - that's incorrect. Only desktop audio should be set to Blackhole 2ch. Change the microphone to the actual mic, and you should be good.
What settings should I choose in the "play sound effects through", "output", and "input" - this is for the global sound settings of the imac
For the audio midi devices: what settings should I choose for the blackhole, ux2, or multi-output devices?
in OBS, what settings should i choose? The condenser microphone connected to my line 6 ux2 hardware interface works with zoom, google meet, skype. OBS for some reason just don't recognize my UX2 microphone. that's my main issue. I also attached pod farm 2 - the audio interface for the UX2.
