OBS quit unexpectedly MAC
So for the past month or so obs has been working great for me until yesterday where it just randomly broke down and I tried every meathod i could find I am using obs-studio-29.1.3-macos-86x_64 I tried to redownload obs fully by deleteing it completely off my computer including ~library and deleteded all files
crash log:
Translated Report (Full Report Below)
Process: OBS [2733]
Path: /Applications/OBS.app/Contents/MacOS/OBS
Identifier: com.obsproject.obs-studio
Version: 29.1.3 (5306902717)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-09-24 09:09:21.4316 -0400
OS Version: macOS 13.4.1 (22F770820d)
Report Version: 12
Bridge OS Version: 7.5 (20P5060)
Anonymous UUID: 1A512AC9-842B-5FBC-058F-51887F992376
Sleep/Wake UUID: 40A8444B-81F8-48F7-B15C-08A2F18DB15B
Time Awake Since Boot: 15000 seconds
Time Since Wake: 706 seconds
System Integrity Protection: enabled
Crashed Thread: 13
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000f0
Exception Codes: 0x0000000000000001, 0x00000000000000f0
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [2733]
VM Region Info: 0xf0 is not in any region. Bytes before following region: 140737487867664
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
shared memory 7ffffff89000-7ffffff8a000 [ 4K] r-x/r-x SM=SHM
UPDATE FIXED
The following taken from the Discord solved the problem for me, hope it helps:
in macOS ventura 13.5.2, logitech's OBS plugin is currently crashing OBS on launch. to remove it:
  1. open Finder and click the Go menu
  2. select "Go to Folder"
  3. paste in the following:
    /Library/Application Support/obs-studio/plugins
    and press enter.
  4. remove the folder for Logitech's OBS plugin. You may also need to disable the plugin in Logitech's software to prevent it from being reinstalled automatically.
  5. launch OBS
Hey, i have a problem with that folder from plugins.
I remove it, In Games-Applications i disabled the OBS integration but it's still coming back :/. Any1 know where do disable it forever?!
Hi everyone,
I'm also getting this this same issue. The folder "Logitech's OBS plugin" keeps coming back upon restart.
Any ways to disable this for good?
Thanking all.
D
    and press enter.
  5. launch OBS
I followed the above instructions, as well as disabling the OBS integration in Logitech, and find that OBS still crashes. Not on that but I don't have an ../obs-studio/plugins folder, only an ../obs-studio/plugin_config folder. Log file for crash attached, I would appreciate any assistance on this! Thanks!
crash log:
Process: OBS [2733]
User ID: 501
Report Version: 12
Crashed Thread: 13
I was able to solve this by uninstalling VLC and OBS, deleting the /Library Support/obs-studio folder and then rebooting, and re-installing OBS. Once I did that, OBS worked. Not clear if this is related, but OBS also released a new version (30) and that worked, where the previous one failed.0
