Bug Report OBS Program White Screen
internetguy
Hey guys, I've been having problems with OBS, I don't know if I've been fiddling around with the setting but when I open it up it has a full white screen, may someone help me and figure out the solution, because I've tried re-installing it but its still white.
Thanks
-Internetguy
I have the log file here you go
09:42:13.536: CPU Name: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
09:42:13.536: CPU Speed: 3400MHz
09:42:13.536: Physical Cores: 4, Logical Cores: 8
09:42:13.536: Physical Memory: 20480MB Total
09:42:13.536: OS Name: Mac OS X (NSMACHOperatingSystem)
09:42:13.536: OS Version: Version 10.13.4 (Build 17E199)
09:42:13.536: Kernel Version: 17.5.0
09:42:13.540: hotkeys-cocoa: Using layout 'com.apple.keylayout.British'
09:42:13.540: Portable mode: false
09:42:13.703: OBS 21.1.1-modified (mac)
09:42:13.703: ---------------------------------
09:42:13.704: ---------------------------------
09:42:13.704: audio settings reset:
09:42:13.704: samples per sec: 44100
09:42:13.704: speakers: 2
09:42:13.705: ---------------------------------
09:42:13.705: Initializing OpenGL...
09:42:13.721: Loading up OpenGL on adapter ATI Technologies Inc. AMD Radeon HD 6970M OpenGL Engine
09:42:13.721: OpenGL loaded successfully, version 4.1 ATI-1.66.31, shading language 4.10
09:42:13.786: ---------------------------------
09:42:13.786: video settings reset:
09:42:13.786: base resolution: 1920x1080
09:42:13.786: output resolution: 1920x1080
09:42:13.786: downscale filter: Bicubic
09:42:13.786: fps: 60/1
09:42:13.786: format: NV12
09:42:13.786: YUV mode: 601/Partial
09:42:13.786: Audio monitoring device:
09:42:13.786: name: Default
09:42:13.786: id: default
09:42:13.929: No blackmagic support
09:42:13.996: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
09:42:14.018: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlc.5.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlc.5.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlc.5.dylib, 1): image not found
09:42:14.018:
09:42:14.018: Couldn't find VLC installation, VLC video source disabled
09:42:14.020: Failed to load 'en-US' text for module: 'obs-browser.so'
09:42:14.020: [browser_source: 'Version: 1.31.0']
09:42:14.021: ---------------------------------
09:42:14.021: Loaded Modules:
09:42:14.021: obs-browser.so
09:42:14.021: vlc-video.so
09:42:14.021: text-freetype2.so
09:42:14.021: rtmp-services.so
09:42:14.021: obs-x264.so
09:42:14.021: obs-vst.so
09:42:14.021: obs-transitions.so
09:42:14.021: obs-outputs.so
09:42:14.021: obs-filters.so
09:42:14.021: obs-ffmpeg.so
09:42:14.021: mac-vth264.so
09:42:14.021: mac-syphon.so
09:42:14.021: mac-decklink.so
09:42:14.021: mac-capture.so
09:42:14.021: mac-avcapture.so
09:42:14.021: linux-jack.so
09:42:14.021: image-source.so
09:42:14.021: frontend-tools.so
09:42:14.021: coreaudio-encoder.so
09:42:14.021: ==== Startup complete ===============================================
09:42:14.040: All scene data cleared
09:42:14.040: ------------------------------------------------
09:42:14.070: coreaudio: device 'Built-in Microphone' initialized
09:42:14.075: Switched to scene 'Scene'
09:42:14.075: ------------------------------------------------
09:42:14.075: Loaded scenes:
09:42:14.075: - scene 'Scene':
09:42:14.075: - source: 'Display Capture' (display_capture)
09:42:15.104: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
09:42:15.590: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
