Question / Help OBS not working after window feature update ..... (Again? )
Ben Luften
(English not good please give me chances)
.Note: I tried to fix the similar issue before and I succeed, It is working properly before (I change few settings from tutorial from youtube) until recent window feature update - I restart my pc and when I open OBS and its not working so I blame it on Bill
- Normally I will use display capture
I tried to fix it by watching youtube
-I tried (basically every way I can find on google)
>restart the pc
>Uninstall and reinstall
>uninstall and restart and then reinstall
>uninstall and delete its folder and clear cache and restart and then reinstall
>restart the pc then Uninstall and reinstall then clear cache and then reinstall then uninstall then delete its folder then reinstall then delete its folder then restart the pc then reinstall ( and it kind work..ing?? I can only use window capture partially - some can and some not)
>Watch youtube teaching switching to integrate graphics in NVIDIA panel.
>Watch YouTuber using 10 different ways .....
>here is links I tried
Non - work perfectly for ME (only/currently)
When I change the scene I can see my mouse pop up in the display for half a sec.
The only thing is can record for now is win. explorer.exe and image (after all the things I had done above)
The other will show mouse pointer for a split sec and still black screen
(I need help fast, I need OBS to rec. a video about a bug in another program )
  • 2020-01-14 12-02-42.txt
  • 2020-01-14 12-05-05.txt
  • 2020-01-14 12-16-52.txt
  • 2020-01-14 12-18-22.txt
  • 2020-01-14 12-19-12.txt
  • 2020-01-14 12-41-42.txt
