Question / Help OBS mutiplatform 0.12.0
cristof
I just download new version (multiplatform 012.0 windows), and I have a bug with add sources.
I right click into source box, then "Add", choice ok, when nothing when I click OK.
I can't add anything.
Thanks for your help
10:30:08.512: CPU Name: Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
10:30:08.512: CPU Speed: 2195MHz
10:30:08.512: Physical Cores: 4, Logical Cores: 8
10:30:08.513: Physical Memory: 3965MB Total, 1755MB Free (NOTE: 4 gigs max is normal for 32bit programs)
10:30:08.513: Windows Version: 6.3 Build 9600 (revision: 17415)
10:30:08.513: Aero is Enabled (Aero is always on for windows 8 and above)
10:30:08.521: OBS 0.12.0 (windows)
10:30:08.521: ---------------------------------
10:30:08.521: audio settings reset:
10:30:08.521: samples per sec: 44100
10:30:08.521: speakers: 2
10:30:08.521: buffering (ms): 1000
10:30:08.523: ---------------------------------
10:30:08.523: Initializing D3D11..
10:30:08.523: Available Video Adapters:
10:30:08.523: Adapter 0: Intel(R) HD Graphics 4000
10:30:08.526: Loading up D3D11 on adapter Intel(R) HD Graphics 4000 (0)
10:30:08.533: D3D11 loaded sucessfully, feature level used: 45056
10:30:09.137: ---------------------------------
10:30:09.137: video settings reset:
10:30:09.137: base resolution: 1366x768
10:30:09.137: output resolution: 1092x614
10:30:09.137: fps: 30/1
10:30:09.137: format: NV12
10:30:09.144: ---------------------------------
10:30:09.144: Loading module: coreaudio-encoder.dll
10:30:09.436: [CoreAudio encoder]: Adding CoreAudio AAC encoder
10:30:09.436: ---------------------------------
10:30:09.437: Loading module: image-source.dll
10:30:09.535: ---------------------------------
10:30:09.535: Loading module: obs-ffmpeg.dll
10:30:09.539: ---------------------------------
10:30:09.540: Loading module: obs-filters.dll
10:30:09.543: ---------------------------------
10:30:09.544: Loading module: obs-outputs.dll
10:30:09.548: ---------------------------------
10:30:09.549: Loading module: obs-x264.dll
10:30:09.552: ---------------------------------
10:30:09.552: Loading module: rtmp-services.dll
10:30:09.556: ---------------------------------
10:30:09.556: Loading module: text-freetype2.dll
10:30:09.836: ---------------------------------
10:30:09.837: Loading module: win-capture.dll
10:30:09.968: ---------------------------------
10:30:09.969: Loading module: win-decklink.dll
10:30:09.979: No blackmagic support
10:30:09.979: Failed to start search for DeckLink devices
10:30:09.979: ---------------------------------
10:30:09.980: Loading module: win-dshow.dll
10:30:09.991: ---------------------------------
10:30:09.992: Loading module: win-mf.dll
10:30:10.007: [Media Foundation encoder]: Adding Media Foundation AAC Encoder
10:30:10.101: ---------------------------------
10:30:10.102: Loading module: win-wasapi.dll
10:30:10.119: =====================================================================
10:30:10.119: output 'simple_stream' (rtmp_output) created
10:30:10.119: encoder 'simple_h264_stream' (obs_x264) created
10:30:10.125: AAC encoder bitrate mapping:
10:30:10.125: 32 kbit/s: 'Encodeur AAC FFmpeg par défaut' (ffmpeg_aac)
10:30:10.125: 64 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 72 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 80 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 96 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 112 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 128 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 144 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 160 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 192 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 224 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 256 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 288 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: 320 kbit/s: 'Encodeur AAC CoreAudio' (CoreAudio_AAC)
10:30:10.125: encoder 'simple_aac' (CoreAudio_AAC) created
10:30:10.125: output 'simple_file_output' (ffmpeg_muxer) created
10:30:10.125: Service '' not found
10:30:10.125: service 'default_service' (rtmp_common) created
10:30:10.126: All scene data cleared
10:30:10.126: ------------------------------------------------
10:30:10.207: WASAPI: Device 'Haut-parleurs (Conexant SmartAudio HD)' initialized
10:30:10.207: source 'Audio du bureau' (wasapi_output_capture) created
10:30:15.709: WASAPI: Device 'Internal Microphone (Conexant SmartAudio HD)' initialized
10:30:15.709: source 'Mic/Aux' (wasapi_input_capture) created
10:30:15.728: == Profiler Results =============================
10:30:15.728: run_program_init: 7235.24 ms
10:30:15.728: ┣OBSApp::AppInit: 2.566 ms
10:30:15.728: ┃ ┗OBSApp::InitLocale: 1.784 ms
10:30:15.728: ┗OBSApp::OBSInit: 7224.1 ms
10:30:15.728: ┣obs_startup: 1.009 ms
10:30:15.728: ┗OBSBasic::OBSInit: 7205.78 ms
10:30:15.728: ┣OBSBasic::InitBasicConfig: 0.469 ms
10:30:15.728: ┣OBSBasic::ResetAudio: 0.268 ms
10:30:15.728: ┣OBSBasic::ResetVideo: 615.825 ms
10:30:15.728: ┣OBSBasic::InitOBSCallbacks: 0.012 ms
10:30:15.728: ┣OBSBasic::InitHotkeys: 0.048 ms
10:30:15.728: ┣obs_load_all_modules: 980.672 ms
10:30:15.728: ┃ ┣obs_init_module(coreaudio-encoder.dll): 5.427 ms
10:30:15.728: ┃ ┣obs_init_module(image-source.dll): 0.003 ms
10:30:15.728: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.019 ms
10:30:15.728: ┃ ┣obs_init_module(obs-filters.dll): 0.007 ms
10:30:15.728: ┃ ┣obs_init_module(obs-outputs.dll): 0.004 ms
10:30:15.728: ┃ ┣obs_init_module(obs-x264.dll): 0.003 ms
10:30:15.728: ┃ ┣obs_init_module(rtmp-services.dll): 0.336 ms
10:30:15.728: ┃ ┣obs_init_module(text-freetype2.dll): 279.019 ms
10:30:15.728: ┃ ┣obs_init_module(win-capture.dll): 114.706 ms
10:30:15.729: ┃ ┣obs_init_module(win-decklink.dll): 4.51 ms
10:30:15.729: ┃ ┣obs_init_module(win-dshow.dll): 1.894 ms
10:30:15.729: ┃ ┣obs_init_module(win-mf.dll): 94.811 ms
10:30:15.729: ┃ ┗obs_init_module(win-wasapi.dll): 0.008 ms
10:30:15.729: ┣OBSBasic::ResetOutputs: 5.595 ms
10:30:15.729: ┣OBSBasic::CreateHotkeys: 0.018 ms
10:30:15.729: ┣OBSBasic::InitService: 0.202 ms
10:30:15.729: ┣OBSBasic::InitPrimitives: 0.238 ms
10:30:15.729: ┗OBSBasic::Load: 5584.3 ms
10:30:15.729: =================================================
10:30:16.379: Update check: last known remote version is 0.12.0
