C c6shy New Member Nov 26, 2024 #1 ive uninstalled it fresh reinstalled (even on dif drives) installed previous version idk why it is now working. Here is the log. Attachments 2024-11-11 10-21-34.txt 2024-11-11 10-21-34.txt 5.6 KB · Views: 41
P prgmitchell Forum Moderator Nov 26, 2024 #2 c6shy said: ive uninstalled it fresh reinstalled (even on dif drives) installed previous version idk why it is now working. Here is the log. Click to expand... have you installed the streamlabs plugin for OBS? if so that may cause this and you'll need to uninstall it, uninstall OBS, then reinstall OBS.
C c6shy New Member Nov 28, 2024 #3 prgmitchell said: have you installed the streamlabs plugin for OBS? if so that may cause this and you'll need to uninstall it, uninstall OBS, then reinstall OBS. Click to expand... streamlabs plugin doesnt appear in the files so i dont think so
C c6shy New Member Nov 28, 2024 #4 prgmitchell said: have you installed the streamlabs plugin for OBS? if so that may cause this and you'll need to uninstall it, uninstall OBS, then reinstall OBS. Click to expand... i js wen to control panel uninstall and it was there. deleted it and it now opened thank you.
