OBS ending stream without notification
KingCluster
Hi everyone,
Stream is running/looking fine but suddenly just ends without telling me. OBS says it's streaming when Twitch says I'm offline. This happens around 1 hour in.
Can someone here take a look at my logs to see if there's something I'm missing? I can't see anything myself. If you find my last stream on Twitch you can see it just ends for no reason.
Thank you
  • 2021-09-05 19-05-49.txt
Your connection isn't able to maintain the bitrate you've selected, and the frequent bitrate fluctuations are causing the encoder to crash.
Given the results in your log:
Settings - Video: Output resolution: 1280x720
Settings - output: bitrate: 4000
And disable dynamic bitrate in settings - advanced.
I'll do this tonight and let you know my results.
You're a good man Harold, don't let anyone tell you otherwise.
Hi Harold and all,
Last night I tried changing my settings once again and got nowhere. Poor resolution and then absolute failure of stream.
I then decided to ditch OBS studio and try a completely refreshed Streamlabs OBS to see if I could get a difference in stream. Nope, the results are as follows.
If anyone can fathom anything from the reports below I would be very appriciative. Thank you so much.
I think my next stop might be messaging my ISP or looking into a new router.
Cheers
Ok cheers Harold. I'm looking into completely new things now.
I've just upgraded my internet to 150mb upload/download so that's my next thing to test.
Secondly, I will text on a whole different computer altogether to see if it's my hardware.
Peace
ok well i'm back again.
Someone in my chat figured out the error from my logs.
WriteN, RTMP send error 10054
Supposed to be to do with my ISP.
