Question / Help OBS AUDIO MAC
richiehawtin
Hi all!
I am new with OBS and i have a problem. I have a MAC and i only want to record the audio of the PC (internal speakers), not the audio of the Microphone,
When i go to Configuration- Audio- Microphone/auxiliar i see:
-Disabled
-Default
-Apowersoft
-Built in Microphone
-System audio recorder
-iShow Audio capture
When i selected any of these and i record. I dont listen nothing, only with Built in Microphone i listen, but i dont want to talk and use the microphone. Why can i see here the internal speakers or do something to only record the audio of internal speakers?
THANKS!!
Do you use an external audio interface? If not you can maybe try to use JackPilot. With this software you can create virtuell audio routings.
Cheers ;)
Why can't i see here the internal speakers or do something to only record the audio of internal speakers?
You can't see the audio devices because apple decided it appropriate to not give us the means to do so.
You need a 3rd party utility such as wavtap or soundflower in order to be able to capture desktop audio
Cheers ;)
No, i cant use an external audio interface, i will like to listen only in my records the audio of the internal speakers...not the sound external of the microphone.
jack pilot can solved it? i go to this page to downloaded but is wrong http://jackaudio.org/
Thanks.
Hi.
I can capture the audio, but if i capture a video with his audio and i record with OBS. I not only listen the sound of the internal speakers because i record across the microphone and not across the speakers...Why can i see here:
-Disabled
-Default
-Apowersoft
The option of speakers?
If you see here in Camtasia you have the option to record with microphone and with speakers (in green) in OBS you can only record with microphone?
Thanks.
