Question / Help OBS 720 or 1080?
Ivanna
Hey so what would the setting be to record in at least 1080P or even 720P? I have this for my settings hopefully a picture shows up.
You're in the wrong section of the settings to set it to 1080/720. The resolution is in the video settings.
Seems as though your confused by the base and scaled resolution options, The base res is the current setting your monitor uses for example 1920x1080, and if its higher than that or you want to stream at 720p then you would select 1280x720 for your scaled res, hope that helps!
