NohBoard
Free NohBoard v1.3.0
here's the screenshot
You must use the "Window Capture" with a "Chroma Key" filter.
Here's screen shots of the Properties and Filters I use:
ive enabled chroma key and i am using windows capture it still wouldnt work i think this issue has been around for about a year or so.
Hey Noah, does the new scripting language options introduced in the last year offer anything tantalizing for this service? like i'm still using the older program, and i don't like that the secondary window sometimes locks up.
might this allow you to skip the window and put something more low-key and less buggy in? or improve things like adding a digital recording that can be overlayed directly into a video editor later or something?
Hello , @ThoNohT and @joao7yt . i am Yalcin Yada, the reason I contacted you is your Noahboard Project. I'm an arcade player and I love to use Noahboard. But the ARcade stick simulations are not available with the keyboard, which I see as a shortcoming. Based on this problem, I did some research and managed to add Arcade Stick simulations to Noahboard. So I edited the pictures in the images folder on the Noahboard and managed to simulate 7 arcade sticks. These ; 1 - ARcade MAME Stick: 2 - Hitbox Simulation: 3 - Playstation Joypad: 4 - Nintendo Joypad: 5 - Sega Joypad: 6 - XboX JoyPad 7 - MixBox Simulation ; I added these simulations and it works fine. You can add these simulations to your work. Many of your users should like you to add Arcade Stick Simulations like me. all can be controlled by keyboard only. Of course, I have no expectations. I'm waiting for your answer
Example Video 1 ; https://www.youtube.com/watch?v=ojmQPUCYy0Q
2 - https://www.youtube.com/watch?v=FCAEK-9BxeU
Sorry if this is already a thing or not. But I would love to see the ability for a button to show as highlighted based on more customizable conditionals.
Use-case scenario: As a surfer I have crouch bound to both left shift and left control so that I don't have issues accidentally fumbling keys, I would like to have just one single button highlight for duck, when I press one or the other.
I also think it'd be nice if I could bind a mouse wheel trigger for the buttons as many surfers and bhoppers will have jump bound to a mousewheel scroll event. I haven't personally gone in and looked at the codebase but perhaps I will check it out relatively soon and see if I'd be able to make a pull request and contribute.
Love the application so far!
ThoNohT updated NohBoard with a new update entry:
The Corona update
Bugs:
- Fixed outline width always being reset to 1.
- Fix mouse speed indicator style changes not applying.
- Disabled mouse/keyboard hooking if there are no keys of this type on the keyboard.
Features:
- Only show the main window in the taskbar.
- Allow changing the title of the NohBoard window.
- Add key codes for Scroll Lock / Num Lock / Caps Lock current state.
- Add a warning message about outlines of loose keys showing underneath pressed keys.
- Added the option to show keys for...
Hello there, first of all, thanks for this amazing work! Exactly what i searched and it looks so easy.
Unfortunatly, i got a little problem with the background-image-option.
However i'm trying to insert a background-image, because i wanted a SNES keyboard, but it wont be displayed, instead i see the background color all the time.
Any Idea?
I also put the SNES.png in all other folders, so i won't miss the right folder for the style, but still no success :(
Here a little list of my files and set options:
Installpath: D:\NohBoard
Config and style-data: D:\NohBoard\keyboards\SNES\SNES
Image-File: D:\NohBoard\keyboards\SNES\SNES\SNES.png
SNES.style-Data:
"BackgroundColor": {
"Blue": 100,
"Green": 0,
"Red": 0
"BackgroundImageFileName": "SNES.png",
"DefaultKeyStyle": {
"Loose": {
"Background": {
"Blue": 100,
"Green": 100,
"Red": 100
"BackgroundImageFileName": null,
"Font": {
"DownloadUrl": null,
"FontFamily": "Courier New",
"Size": 10,
"Style": 0
"Outline": {
"Blue": 0,
"Green": 255,
"Red": 0
"OutlineWidth": 1,
"ShowOutline": false,
"Text": {
"Blue": 0,
"Green": 0,
"Red": 0
"Pressed": {
"Background": {
"Blue": 255,
"Green": 255,
"Red": 255
"Font": {
"Size": 10,
"Style": 0
"Outline": {
"Blue": 0,
"Green": 255,
"Red": 0
"OutlineWidth": 1,
"Text": {
"Blue": 0,
"Green": 0,
"Red": 0
"DefaultMouseSpeedIndicatorStyle": {
"InnerColor": {
"Blue": 100,
"Green": 100,
"Red": 100
"OuterColor": {
"Blue": 255,
"Green": 255,
"Red": 255
"OutlineWidth": 1
"ElementStyles": [ ]
Is there a way that I can force Nohboared always on top, so that I could run a game and Nohboared on the screen at the same time? I've been able to do this using a small program called Deskpins, but it forces the keyboard/mouse input to register in Nohboard, not the game (since it's on top).
I also know we could do this using OBS, so that both a game and Nohboared appear on a stream or separate window. I'm trying to get them to display on my one screen simultaneously without OBS tho.
When I'm running my NohBoard and I'm playing a game (Fortnite Don't make fun of me) when i look around and stuff my mouse like cuts out and stops for a second then goes again. Is there something with having wireless mouse's maybe. Is there some type of fix for it.
Any Idea?
SNES.style-Data:
"Blue": 100,
"Green": 0,
"Red": 0
"Loose": {
"Background": {
"Blue": 100,
"Green": 100,
"Red": 100
"Font": {
"Size": 10,
"Style": 0
"Outline": {
"Blue": 0,
"Green": 255,
"Red": 0
"OutlineWidth": 1,
"Text": {
"Blue": 0,
"Green": 0,
"Red": 0
"Pressed": {
"Background": {
"Blue": 255,
"Green": 255,
"Red": 255
"Font": {
"Size": 10,
"Style": 0
"Outline": {
"Blue": 0,
"Green": 255,
"Red": 0
"OutlineWidth": 1,
"Text": {
"Blue": 0,
"Green": 0,
"Red": 0
"InnerColor": {
"Blue": 100,
"Green": 100,
"Red": 100
"OuterColor": {
"Blue": 255,
"Green": 255,
"Red": 255
"OutlineWidth": 1
Images need to be in an \Images folder in the Definition subfolder. Ex: keyboards\Definition\Images\SNES.png
I use AutoHotKey with a simple script below
1.) Install AutoHotKey
2.) Create a text file and name it AlwaysOnTop.ahk
3.) Copy and Paste the script below. DO NOT copy the dash lines.
#NoEnv
SendMode Input
SetWorkingDir %A_ScriptDir%
^SPACE:: Winset, Alwaysontop, , A
Appreciate all the help from this tool. Would love to see a couple options for Dual PC streamers.
Transparent background since Chroma key can't be used.
Ability to auto-hide the tool when not input is registered.
Ability to force to AlwaysOnTop (like when using AutoHotKey)
Complete Layouts per Manufacturer for Keyboards and Mice. Basic image layouts would be nice at least. Basic Icons for Keyboards.
Otherwise great tool and can't wait to see if we get more options. For now I may start creating layouts for my Logitech Gear.
Hmm. I wonder if this could work with a Racing Sim setup (Wheel, pedals and shifter). How about flight-sticks?
Hi
I just discover this plugin and I would to custimize it with community themes but I don't understand how it works (it's been an hour I edit things and read the wiki T_T ).
Someone can explain me where I put the code people share ?
