Bug Report Menu bar missing
Upgraded to OBS 0.12.0-285~trusty, yet the problem persists in laptop. :(
Desktop: http://picpaste.com/1a2e418aaf433d33bfcc3adaa4332955.png (the top menu bar is visible)
Laptop: http://picpaste.com/9RQOjYtv.png (the top menu bar is NOT visible)
Log:
07:34:52.708: Processor: 4 logical cores
07:34:52.708: Processor: AMD A10-5750M APU with Radeon(tm) HD Graphics
07:34:52.708: Physical Memory: 7127MB Total
07:34:52.708: Kernel Version: Linux 3.18.8-031808-lowlatency
07:34:52.716: Distribution: "Ubuntu" "14.04"
07:34:53.179: OBS 0.12.0 (linux)
07:34:53.179: ---------------------------------
07:34:53.180: ---------------------------------
07:34:53.180: audio settings reset:
07:34:53.180: samples per sec: 48000
07:34:53.180: speakers: 2
07:34:53.180: buffering (ms): 1000
07:34:53.415: OpenGL version: 3.3 (Core Profile) Mesa 10.1.3
07:34:53.415:
07:34:53.545: ---------------------------------
07:34:53.545: video settings reset:
07:34:53.545: base resolution: 1920x1080
07:34:53.545: output resolution: 1920x1080
07:34:53.545: fps: 24/1
07:34:53.545: format: NV12
07:34:53.549: ---------------------------------
07:34:53.550: Loading module: image-source.so
07:34:53.550: ---------------------------------
07:34:53.551: Loading module: linux-capture.so
07:34:53.552: ---------------------------------
07:34:53.553: Loading module: linux-decklink.so
07:34:53.554: No blackmagic support
07:34:53.554: Failed to start search for DeckLink devices
07:34:53.554: ---------------------------------
07:34:53.555: Loading module: linux-jack.so
07:34:53.555: ---------------------------------
07:34:53.556: Loading module: linux-pulseaudio.so
07:34:53.556: ---------------------------------
07:34:53.561: Loading module: linux-v4l2.so
07:34:53.561: ---------------------------------
07:34:53.563: Loading module: obs-ffmpeg.so
07:34:53.563: ---------------------------------
07:34:53.564: Loading module: obs-filters.so
07:34:53.564: ---------------------------------
07:34:53.581: Loading module: obs-libfdk.so
07:34:53.581: ---------------------------------
07:34:53.582: Loading module: obs-outputs.so
07:34:53.582: ---------------------------------
07:34:53.583: Loading module: obs-x264.so
07:34:53.583: ---------------------------------
07:34:53.584: Loading module: rtmp-services.so
07:34:53.606: ---------------------------------
07:34:53.607: Loading module: text-freetype2.so
07:34:53.607: =====================================================================
07:34:53.608: output 'adv_stream' (rtmp_output) created
07:34:53.608: output 'adv_file_output' (ffmpeg_muxer) created
07:34:53.608: encoder 'recording_h264' (obs_x264) created
07:34:53.608: encoder 'streaming_h264' (obs_x264) created
07:34:53.608: AAC encoder bitrate mapping:
07:34:53.608: 32 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
07:34:53.608: 64 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
07:34:53.608: 96 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
07:34:53.608: 128 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
07:34:53.608: 160 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
07:34:53.608: 192 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
07:34:53.608: 224 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
07:34:53.608: 256 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
07:34:53.608: 288 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
07:34:53.608: 320 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
07:34:53.608: encoder 'adv_aac0' (libfdk_aac) created
07:34:53.608: encoder 'adv_aac1' (libfdk_aac) created
07:34:53.608: encoder 'adv_aac2' (libfdk_aac) created
07:34:53.608: encoder 'adv_aac3' (libfdk_aac) created
07:34:53.637: Service '' not found
07:34:53.637: service 'default_service' (rtmp_common) created
07:34:53.648: All scene data cleared
07:34:53.648: ------------------------------------------------
07:34:53.649: source 'Composite-alt1' (scene) created
07:34:53.650: xshm-input: Geometry 1920x1080 @ 0,0
07:34:53.655: source 'Screen Capture (XSHM)' (xshm_input) created
07:34:53.656: source 'Image' (image_source) created
07:34:53.656: v4l2-input: Start capture from /dev/video1
07:34:53.684: v4l2-input: Input: 0
07:34:53.686: v4l2-input: Resolution: 1280x720
07:34:53.686: v4l2-input: Pixelformat: 21UY
07:34:53.686: v4l2-input: Linesize: 1280 Bytes
07:34:53.690: v4l2-input: Framerate: 24,00 fps
07:34:53.693: source 'C920Camera' (v4l2_input) created
07:34:53.712: source 'Chroma Key' (chroma_key_filter) created
07:34:53.714: source 'Crop' (crop_filter) created
07:34:53.715: source 'Image Mask/Blend' (mask_filter) created
07:34:53.720: source 'Color Correction' (color_filter) created
07:34:53.772: pulse-input: Server name: 'pulseaudio 4.0'
07:34:53.773: pulse-input: Audio format: s16le, 32000 Hz, 2 channels
07:34:53.773: pulse-input: Started recording from 'alsa_input.usb-046d_HD_Pro_Webcam_C920_4C66D5DF-02-C920.analog-stereo'
07:34:53.773: source 'C920Audio' (pulse_input_capture) created
07:34:53.774: source 'Closeup-alt2' (scene) created
07:34:53.774: source 'Presentation-alt3' (scene) created
07:34:53.805: xcompcap: XCompositeRedirectWindow failed: BadWindow (invalid Window parameter)
07:34:53.805: source 'Presentation' (xcomposite_input) created
07:34:53.931: pulse-input: Server name: 'pulseaudio 4.0'
07:34:53.931: pulse-input: Sample spec is not valid
07:34:53.931: Failed to create source 'H4nAudio'!
07:34:53.931: source 'H4nAudio' (pulse_input_capture) created
07:34:53.968: [ffmpeg] [png @ 0x7f66f8088340] Broken zTXt chunk
07:34:53.991: == Profiler Results =============================
07:34:53.991: run_program_init: 2581,47 ms
07:34:53.991: ┣OBSApp::AppInit: 36,619 ms
07:34:53.992: ┃ ┗OBSApp::InitLocale: 1,031 ms
07:34:53.992: ┗OBSApp::OBSInit: 1346,2 ms
07:34:53.992: ┣obs_startup: 9,83 ms
07:34:53.992: ┗OBSBasic::OBSInit: 810,905 ms
07:34:53.992: ┣OBSBasic::InitBasicConfig: 0,746 ms
07:34:53.992: ┣OBSBasic::ResetAudio: 0,146 ms
07:34:53.992: ┣OBSBasic::ResetVideo: 368,549 ms
07:34:53.992: ┣OBSBasic::InitOBSCallbacks: 0,01 ms
07:34:53.992: ┣OBSBasic::InitHotkeys: 0,068 ms
07:34:53.992: ┣obs_load_all_modules: 58,167 ms
07:34:53.992: ┃ ┣obs_init_module(image-source.so): 0,003 ms
07:34:53.992: ┃ ┣obs_init_module(linux-capture.so): 0,918 ms
07:34:53.992: ┃ ┣obs_init_module(linux-decklink.so): 0,248 ms
07:34:53.992: ┃ ┣obs_init_module(linux-jack.so): 0,004 ms
07:34:53.992: ┃ ┣obs_init_module(linux-pulseaudio.so): 0,002 ms
07:34:53.992: ┃ ┣obs_init_module(linux-v4l2.so): 0,004 ms
07:34:53.992: ┃ ┣obs_init_module(obs-ffmpeg.so): 0,019 ms
07:34:53.992: ┃ ┣obs_init_module(obs-filters.so): 0,008 ms
07:34:53.992: ┃ ┣obs_init_module(obs-libfdk.so): 0,004 ms
07:34:53.992: ┃ ┣obs_init_module(obs-outputs.so): 0,004 ms
07:34:53.992: ┃ ┣obs_init_module(obs-x264.so): 0,002 ms
07:34:53.992: ┃ ┣obs_init_module(rtmp-services.so): 21,36 ms
07:34:53.992: ┃ ┗obs_init_module(text-freetype2.so): 0,029 ms
07:34:53.992: ┣OBSBasic::ResetOutputs: 0,825 ms
07:34:53.992: ┣OBSBasic::CreateHotkeys: 1,556 ms
07:34:53.992: ┣OBSBasic::InitService: 27,523 ms
07:34:53.992: ┣OBSBasic::InitPrimitives: 8,58 ms
07:34:53.992: ┗OBSBasic::Load: 293,064 ms
07:34:53.992: =================================================
07:34:54.016: [ffmpeg] [png @ 0x7f66f808f540] Broken zTXt chunk
07:34:54.021: [ffmpeg] [png @ 0x7f66f808eba0] Broken zTXt chunk
07:34:54.028: [ffmpeg] [png @ 0x7f66f808f040] Broken zTXt chunk
07:34:54.034: [ffmpeg] [png @ 0x7f66f8073ac0] Broken zTXt chunk
07:34:54.043: [ffmpeg] [png @ 0x7f66f8089560] Broken zTXt chunk
07:34:54.465: Audio line 'C920Audio' audio data currently getting cut off. This could be due to a negative sync offset that's larger than the current audio buffering time.
07:34:54.490: Audio line 'C920Audio' audio data no longer getting cut off.
07:34:54.552: Update check: last known remote version is 0.4.0
07:45:56.438: source 'Composite-alt1' destroyed
07:45:56.446: source 'Screen Capture (XSHM)' destroyed
07:45:56.447: source 'C920Audio' destroyed
07:45:56.448: pulse-input: Stopped recording from 'alsa_input.usb-046d_HD_Pro_Webcam_C920_4C66D5DF-02-C920.analog-stereo'
07:45:56.448: pulse-input: Got 104624 packets with 21200825 frames
07:45:56.464: source 'Closeup-alt2' destroyed
07:45:56.465: source 'Image' destroyed
07:45:56.465: source 'Color Correction' destroyed
07:45:56.465: source 'Image Mask/Blend' destroyed
07:45:56.465: source 'Crop' destroyed
07:45:56.465: source 'Chroma Key' destroyed
07:45:56.465: source 'C920Camera' destroyed
07:45:56.473: v4l2-input: Stopped capture after 11840 frames
07:45:57.336: source 'Presentation-alt3' destroyed
07:45:57.336: source 'Presentation' destroyed
07:45:57.336: source 'H4nAudio' destroyed
07:45:57.336: All scene data cleared
07:45:57.336: ------------------------------------------------
07:45:57.336: service 'default_service' destroyed
07:45:57.336: encoder 'recording_h264' destroyed
07:45:57.336: encoder 'streaming_h264' destroyed
07:45:57.336: encoder 'adv_aac3' destroyed
07:45:57.336: encoder 'adv_aac2' destroyed
07:45:57.336: encoder 'adv_aac1' destroyed
07:45:57.337: encoder 'adv_aac0' destroyed
07:45:57.337: output 'adv_stream' destroyed
07:45:57.337: output 'adv_file_output' destroyed
07:45:57.383: Freeing OBS context data
Purged obs-studio (apt-get purge obs-studio), checked whether any remains of obs in /usr/share (none found), reinstalled (sudo gdebi /var/cache/apt/archives/obs-studio_0.12.0-285~trusty_amd64.deb as well as apt-get install --reinstall obs-studio) and launched obs in command line without any change (still no top menu bar).
Log: http://pastebin.com/tKVyJubS
I'm having the same problem - no menu bar on my MacBook Monterey, and I couldn't find the package "appmenu-qt5" on my system.
