macos display capture & chroma key
sknuutin
On Sonoma 14.2.1 and OBS 30.0.2 the attached file causes problem when doing display capture or window capture with chroma key. For some reason the chroma key is not able to filter out that test file no matter what I try. On Windows 11 machine this works without problems. Could somebody try on MacOS and OBS 30.0.2 if you can repeat the problem or if it works ok and I'm missing something? The steps to reproduce the problem are really simple just add display or window capture and add filter chroma key and then open the attached test file and see if it is filtered with the chroma key or not.
Thanks
