The reason your screen recordings are missing one side of the audio is an iOS audio routing limitation: when a live video chat (using WebRTC in Safari, like Monkey or OmeTV) activates your iPhone's microphone, iOS treats the session like a phone call. Standard iOS Screen Recording cannot capture internal call audio and live microphone input simultaneously—it either mutes the other person's audio for privacy or drops your mic.
The creators you see making those videos on iPhone are using one of three workarounds.
Method 1: Speakerphone + Screen Record with Mic On (No Extra Gear)
The easiest way to capture both voices directly on your iPhone without a computer or extra apps is to let your iPhone's microphone pick up the other person's voice coming out of your phone's speaker.
1.Unplug Headphones and Maximize Volume:1 min.
Disconnect any AirPods or wired headphones so the chat audio plays out loud through your iPhone's speakers, and turn your media/call volume up to
80–100%.
Verification: You can clearly hear the other person speaking out loud from your phone in a quiet room.
2.Enable the Screen Recording Microphone:Control Center.
Swipe down from the top-right corner of your screen to open
Control Center. Touch and hold the
Screen Recording button (the circle inside a circle), tap the
Microphone icon at the bottom so it turns red and reads
Microphone On, then tap
Start Recording.
Verification: A red recording pill or timer appears at the top of your screen after the 3-second countdown.
3.Start Your Safari Chat:Safari.
Switch back to Safari and start your Monkey or OmeTV session. Because the mic is recording the room, it captures both your voice and the other person's voice coming from the speaker.
Verification: After ending the recording, play the video back in your Photos app and confirm both voices are audible.
Tip: Record in a quiet room and keep your phone at arm's length on a stand. If the volume is too loud, the other person might hear an echo of themselves.
Method 2: Use a Second Device for Clean Audio (Best Quality Without a PC)
If the speakerphone method sounds too echoey, use a second phone, iPad, or cheap clip-on mic setup to record your voice separately, then merge them.
- Record the Screen Only on iPhone: Open Control Center, hold Screen Recording, turn Microphone Off, and record your Safari session. Without the mic competing for the audio channel, iOS is much more likely to capture the clean internal audio of the person you are talking to (if Safari doesn't block it).
- Record Your Voice on a Second Device: Open the Voice Memos app on an old phone, iPad, or laptop sitting next to you and hit record at the same time.
- Sync in CapCut: Import the screen recording and the voice memo into a free mobile editor like CapCut, line up your voice with your mouth movements on screen, and export.
Method 3: Connect Your iPhone to a Mac or Windows PC (Pro Creator Setup)
Almost every viral Monkey/OmeTV creator who gets crisp, studio-quality audio on both sides is mirroring their iPhone to a computer.
- On a Mac (Built-in, Free):
- Plug your iPhone into your Mac with a USB/Lightning cable.
- Open QuickTime Player on the Mac and go to File > New Movie Recording.
- Click the small downward arrow next to the red record button and select your iPhone for both Camera and Microphone (this pulls the internal audio and video from your phone).
- Use OBS Studio (free) on your Mac to capture the QuickTime window alongside a separate microphone plugged into your Mac so both audio tracks stay clean and balanced.
- On a Windows PC:
- Use a screen-mirroring app that supports audio routing (such as LonelyScreen, ApowerMirror, or Elgato Screen Link) alongside OBS Studio to capture the mirrored iPhone feed and your PC microphone together.
A Note on Browsers & Apps on iPhone
Switching from Safari to Chrome, Firefox, or Brave on iPhone will
not fix this by itself. Apple requires every third-party web browser on iOS to use Safari's underlying engine (WebKit) and follow the exact same iOS audio-routing rules. Stick with
Safari, as it has the fewest camera/mic permission glitches on sites like Monkey and OmeTV.
For a quick visual walkthrough of setting up iPhone screen recording with audio, check out this guide:
How to Record iPhone Screen with Sound (Internal & Mic Audio).
