Question / Help Installation ERROR
LincePlays
I cannot send you commands, you need to investigate on your own if your apt is configured correctly.
They should already be there by default. If they are not your installation is faulty or some custom build from your VPS provider and you need to figure out how to fix it on your own. If you don't know how to use a simple tool like apt, you should probably not be using Linux.
You know you can't run OBS from command line, right? And that it requires a proper GPU to function?
Most VPS will not have any GPU in them, and OBS will not function without one.
