Help With Live Audio Stream
AFAIK, OBS does not support audio only streams. You can stream to YouTube and just have the "video" be all black or a static image/text, etc. The YouTube Service Stream may not work currently with OBS 27.2.4 so you may need to use the Custom... Service and input the Server and Stream Key.
If you're going to that route (static content) you can use a low FPS (such as 5) and lower the output resolution to 480 and bitrate.
1. You are running the 32 bit version of OBS on a 64 bit system. This will reduce performance and greatly increase the risk of crashes due to memory limitations. You should only use the 32 bit version if you have a capture device that lacks 64 bit drivers. Please run OBS using the 64-bit shortcut. You can download the 64 bit version from https://github.com/obsproject/obs-studio/releases/tag/27.2.4 if it's not installed.
2. Your audio device has a sample rate that doesn't match the OBS Sample Rate. This can result in audio drift over time or sound distortion. Check your audio devices in Windows settings (both Playback and Recording) and ensure the Default Format (under Advanced) is consistent. 48000 Hz is recommended.
OBS Sample Rate: 48000 Hz
Line 1/2 (M-Audio Delta 1010LT): 44100 Hz
3. Make sure you have newest drivers for your processor. You can download those from https://www.intel.com/content/www/u...cessor-6m-cache-up-to-3-30-ghz/downloads.html
"If you want an audio-only stream, you're probably better off just setting up an audio-only stream system using something like Icecast and a compatible broadcasting tool."-Harold
