Game lags/stutters and/or dropped frames.
BCool1138
I have 2017 2.3 GHz Dual-Core Intel Core i5 with 16 gigs of ram. When streaming (via restream) to twitch and kick I get laggy play back. I've watched tons of videos about "the best settings" but I was hoping I'd find someone with a pretty similar set up so I can compare settings. I'm 1/2 tempted to blame the upload speed of my internet. I have tried streaming a few things, Fortnite via luna game lags and stream lags. As well as run-on openemu playing Zelda. It looks like 10 gigs of ram is still available, and my processor is on 40-50% occupied. 1 down side is the CPU is running around 150* (going to get that fixed shortly). I'd like to get this resolved so that I can continue to stream on my lunch breaks.
Current settings. Kick recommended 3500 bitrate or I the stream would start and stop. I was running 264 hardware, but x264 doesn't seem to make a difference. I'm wondering if the CPU other settings should be set differently.
I don't know what FPS you're using, but the 'Rescale Output' is probably hurting your performance quite a bit. You should definitely use the H264 hardware encoding if it's not crashing your computer--it's a better starting point.
我有 2017 年 2.3 GHz 双核 Intel Core i5 和 16 GB 内存。当流式传输(通过重播)到抽搐和踢腿时,我的播放会延迟。我看过很多关于“最佳设置”的视频,但我希望我能找到一个设置非常相似的人,这样我就可以比较设置。我有 1/2 的诱惑归咎于我的互联网的上传速度。我尝试过流式传输一些东西,Fortnite 通过 luna 游戏滞后和流滞后。以及玩塞尔达的 openemu。看起来 10 GB 的内存仍然可用,我的处理器占用率为 40-50%。1 不利的一面是 CPU 在 150* 左右运行(很快就会修复)。我想解决这个问题,这样我就可以在午休时间继续直播。
你的显卡是什么型号?我觉得问题是您的显卡刷新率低。
I don't know what FPS you're using, but the 'Rescale Output' is probably hurting your performance quite a bit. You should definitely use the H264 hardware encoding if it's not crashing your computer--it's a better starting point. View attachment 99216
Thanks I was for up until this picture. I spent the morning talking to restream and hope I found an answer. The biggest thing they had me do was to change my server destination.
restream suggested these settings. If I change it from x264 to H264 hardware I loose settings under encoder settings
