Question / Help freezing while streaming!!!
tony123
i have been using OBS STUDIO since day one i didn't have any issues but got noticed its freezing while streaming.
see the attached images
if anyone can help me it would be awesome
  • 2017-08-23 21-05-50.txt
Log needs to contain a stream attempt where the freeze occurs. That log only contains OBS' successful initial setup and nothing else.
Although I do see a media source with a file it can't open:
21:06:13.564: MP: Failed to open media: '/Volumes/AVANISH/CMR FINAL 2017.mp4'​
And if you're having freezes, stutters or slowdowns, increasing CPU preset speed is always a good idea:
21:06:22.050: [x264 encoder: 'streaming_h264'] preset: veryfast​
Perhaps start at the fastest, ultrafast, and see if the problem goes away, and then tune until you get the quality you need.
see the attach pls
I tried from fast to ultrafast n etc still the result is same
is there any other way to fix it ??
Suggest looking in your console. The log shows a streaming start but not a stop, so either the program didn't exit successfully or it froze during the stream and stopped writing data to the log.
