FreeFX - StreamFX Fork
FreeFX - StreamFX Fork 0.12.0b299
1.0.0b407??
There is a shader in Streamfx and FreeFX that does upscaling. It works quite well, better in the latest versions of StreamFX (it has better performance). The final output is very similar to that shader
But with an RXT 4090 I lose 50% GPU performance when scaling a 2160p signal to 8k. It can be used on a streaming PC.
Yes, but but I don't an NVIDIA gpu...
Also I prefer Anime 4k because it does look good with rpg maker games.
Does this version works with OBS 30?
I've tried one build to test the "auto framing" filter and nothing happened. (I have a RTX 3080ti)
I couldn't find a way to install FreeFx OR an older build of StreamFX I still have. Somehow it refuses to work under version 30.0.2 when I'm on Kubuntu 2404. Wish this was updated.
It's definitely broken with the current (30.2.0) update.
I seem to have found an easy solution. I had the same issue on my Windows 10 system. Initial solution was just to reinstall, from the full installer, version 30.1, just to see if I could the functionality of FreeFX back. This worked, and I decided I would just wait to see if there were any solutions before attempting to update OBS again at some point in the future. In the meantime I did some digging, and found other users having issues, different issues related to streaming, and that apparently the problem was the in-app updater. Supposedly it removed files that were necessary for OBS. I decided to try the update again to 30.2 using the full installer, and now I have it updated and FreeFX still working. I haven't put it through it's paces to make sure that everything is 100% fine, but at first glace, all seems fine, and the FreeFX filters are there. Perhaps it's not even necessary to reinstall 30.1 first. That's just the route I took because my intention was just to roll back. Also, I never ran any uninstall routines. I simply ran the full installer and let it install in the same directory over top of itself.
Yeah I'm just not able to get this to work or show up at all in the newest OBS version. I guess I'll have to hope this gets updated eventually.
Update, tried EXACTLY what you suggested, rolled back to the previous version and then full-installed 30.2.0 and it seems to be working!
I've tried this but unfortunately didnt have any success in getting freefx to work on the latest version.
Has anybody been able to find a work around?
OBS 30.2.2: I installed Free FX just as I usually do with any other plugin, just as you did. However, there seems to be a problem for the plugin to load in when I open OBS. None of the features appear in the "Filters" menu. I even tried to drag and drop the plugin .dll and .pdb and the Free FX folder into the OBS Directory bin and data folders but still nothing. I have closed OBS and restarted my PC, but still nothing. Is Free FX not updated to be compatible with OBS 30.2.2 anymore? What can I do?
I have tested on 29.1.1, can you try that one?
Hi guys,
I've this problem with my attemp to install this plugin.
Some Details about my tests:
- My OS is Windows 10pro 64
- I've tried it on these OBS versions: 30.2.2, 29.1.1, 28.1.2
- I've installed from Installer.exe and .ZIP
- I've installed in 2 different computers
But, the same error persists.
Any tips from someone, please ?
I installed OBS 3.2, cant see the StreamFX/FreeFX tab but upon checking log and encoders, it seems to be installed cuz I can see streamfx encoders, so I guess its working?
