Failed to start recording NVENC Error: init_encoder_h264: nv.nvEncinitializeEncoder(enc->session, &enc->params) failed: 8 (NV_ENC_ERR_INVALID_PARAM)
Upek Hansaja
When I set Encoder to NVIDIA NVENC H.264 and try to start recording this error msg comes
But a couple of months ago it worked fine :(
What can I do about that and how can I overcome that error?
Please Help me to solve this trouble...:(
15:26:16.999: [jim-nvenc] init_encoder_h264: nv.nvEncInitializeEncoder(enc->session, &enc->params) failed: 8 (NV_ENC_ERR_INVALID_PARAM): ::NV_ENC_TWO_PASS_FULL_RESOLUTION is only supported multipass encoding on this architecture.
Use multipass mode single or full res. It is also better to choose preset P4
If that doesn't work, you'll have to revert to OBS 28.0.3
Oh..
Thank you very much, dear friend
It working perfectly ❤
But now it seems my voice is not audible at the recording
log
You have 2 input devices. Select the correct default device in Windows and specify it in OBS in the audio section
18:21:44.683: WASAPI: Device 'Speakers (Realtek High Definition Audio)' [48000 Hz] initialized
18:21:44.706: WASAPI: Device 'Microphone (A4tech FHD 1080P PC Camera)' [48000 Hz] initialized
Check your microphone volume in Windows and make sure it works fine in OBS -20 db to -6
Also, you may not have configured these filters correctly
18:21:44.629: - filter: 'Noise Suppression' (noise_suppress_filter_v2)
18:21:44.629: - filter: 'Noise Gate' (noise_gate_filter)
18:21:44.629: - filter: 'Gain' (gain_filter)
Thank you very much
Its now perfectly Working...
Thank you again for helping me throughout the day :)
