Bug Report Error box pops up when launching OBS Studio 32 AND 64bit
ChaosGamerTV
The error box message says
The program can't start because MSVCP120.dll is missing from your computer. Try reinstalling the program to fix the problem.
Another one...
The program can't start because MSVCR120.dll is missing from your computer. Try reinstalling the program to fix the problem.
And another....
The program can't start because MSVCP120.dll is missing from your computer. Try reinstalling the program to fix the problem. That error message is the same as the 1st one as you can see.
I think this is the last one...
The program can't start because MSVCR120.dll is missing from your computer. Try reinstalling the program to fix the problem. That error message is the same as the 2nd one as you can see.
I keep getting all those same error messages when trying to launching both 32bit and 64bit version of OBS Studio. If any dev or mod could notice this quick please.
Also why would it show the same error message twice?
I have no log file. Only the uploaded pictures.
That error is telling you it can't find a DLL that is specifically part of the runtime, please try uninstalling from control panel and then reinstalling from the link and let us know what happens
I think somehow it fixed itself because recently my computer was down and when I reset it to factory settings it was able to recognize the source file after installing all the framework and stuff.
